Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products
My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
Thumbnail
1FN3002-0PH00-0AA0
HALL SENSOR BOX, STR. CABLE OUTLET, 2.4M
SIMOTICS L Hall sensor box for determining the pole position (commutation); straight cable outlet; for size 050 to 150; PRI length 2.4 (standard); 2.3,4,5 (version)
  • Save filter
  • Load filter
  • e-mail on update
36
Entries
Filtered by
1FN3002-0PH00-0AA0
Entries per page: 20 50 100
1
2
Product note Sales release of new interconnection variants for SINAMICS G115D motor mounted and SINAMICS G115D wall mounted
With immediate effect, new interconnection variants have been released for sales for SINAMICS G115D motor mounted and SINAMICS G115D wall mounted.
09/21/2021
(1)
Certificate General Product Approval, CCC
China Compulsory Product Certificate 562-13-DFC
05/07/2021
(1)
FAQ Where can you find data sheets, dimension sheets, CAD data, 2/3-D views of the SIMOTICS S, M, L, T motors?
01/30/2020
(4)
Certificate Declaration of Conformity, EC/EU-Declaration of Conformity, Manufacturer
EC-Declaration of Conformity 664.20043.04
11/11/2019
(0)
Product note Redesign of SIMOTICS L-1FN3 precision cooler
The precision cooler for the SIMOTICS L-1FN3 primary section has been reworked and now includes new, enhanced properties.
10/16/2019
(1)
Manual SIMOTICS L-1FN3 Linear Motors for SINAMICS S120
10/2018, Configuration Manual, 6SN1197-0AB86-0BP2, 6SN1197-0AB86-0BP2
01/16/2019
(6)
Product note Technical documentation SIMOTICS
Regardless of which application you are dealing with, whether you are doing a quick search online for help for a current machine message during operation, you want to familiarize yourself with a product, or you would like to compile your individual documentation: You will find the right current editions of the technical document. in electronic form, on data carriers, and printed.
10/29/2018
(13)
Certificate Test Certificates, Declaration of the Compliance with the order, Manufacturer
Certificate of compliance with the order „type 2.1“ 2.1
07/06/2018
(3)
Product note SIMOTICS L-1FN3 - New spare parts kits for terminal box cover with seal
Due to a design change to the terminal box, SIMOTICS L-1FN3 motors are supplied with an optimized seal between terminal box cover interface and motor housing. This provides additional variants for the spare parts kits, comprising terminal box cover with seal.
04/18/2018
(0)
Product note SIMOTICS L-1FN3 - changes to the converter setting parameters
With the publication of SINAMICS V5.1 and SINUMERIK V4.8 SP2, modified velocity data for SIMOTICS L-1FN3 has been saved to the converter setting database. When operated with SINAMICS, this change means that the motors can fully utilize their maximum power limit, and they can be operated up to the maximum motor velocity.
03/14/2018
(0)
Catalog/Brochure Catalog D 21.4 N: SINAMICS S120 and SIMOTICS
News 10/2017, Catalog, E86060-K5521-E141-A1-7600
For products: 6SL3...-.....-....
11/22/2017
(3)
Certificate General Product Approval, UL, UL
Certificate of Compliance 20131111-E93429
05/05/2017
(0)
Certificate China-RoHS, Manufacturer
Statement to China-RoHS directive for Low-voltage products
08/22/2016
(0)
EU Declaration of Conformity 664.20043.02
04/20/2016
(0)
FAQ SIMOTICS L-1FN3: Installation
Additional Information to the Configuration Manual (CM) or the current operating instructions (OI)
01/26/2016
(0)
FAQ SINAMICS, SIMOTICS: Discontinuation of the KTY84-130 temperature sensor
08/05/2015
(2)
FAQ SIMOTICS: Description of the order codes for the motor options
In Spares on Web, by entering the serial number, you can identify which options have been installed in a motor, and what these mean.
07/22/2015
(2)
FAQ Spare parts, repair services for SINUMERIK, SINAMICS
SINUMERIK, SINAMICS, SIMODIRVE, SIMOVERT, MASTERDRIVES, MICROMASTER, COMBIMASTER, POSMO, SIMOTION, SIMOTICS
04/24/2015
(6)
FAQ Alignment, alignment values, alignment methods, alignment in relation to thermal growth, alignment in relation to journal bearings, alignment tool
  QUESTION:...
04/15/2013
(2)
FAQ Structure and designation of grease for rolling-contact bearings
  QUESTION:...
05/22/2012
(2)
1
2
