Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
Thumbnail
1FW6150-0PB15-2JQ2
TORQUE MOTOR STATOR A. ROTOR PRE-ASSEMBL
TORQUE MOTOR; COMPONENT 3-PHASE SYNCHRONOUS MOTOR; EXTERNAL COOLING JACKET; AXIAL CABLE OUTLET; CABLE LENGTH 3M WITHOUT CONNECTOR DIAM 385MM; LENGTH 210MM; MAX TORQUE 2130NM; MAX ROT SPEED 100 RPM; MAX CURRENT 66 ARMS; WHEN USING THE DIRECT MOTORS ON FORK HEADS FOR MACHINE TOOLS OR ROBOTS A LICENSE FOR US PATENT US5584621 AND THE CORRESPONDING WORLDWIDE PATENTS MAY BE REQUIRED
  • Save filter
  • Load filter
  • email on update
20
Entries
Filtered by
1FW6150-0PB15-2JQ2
Entries per page: 20 50 100
1
Certificate Test Certificates, Declaration of the Compliance with the order, Manufacturer
Certificate of compliance with the order „type 2.1“ 2.1
07/06/2018
(3)
Certificate General Product Approval, CCC
China Compulsory Product Certificate 562-9-DFC
06/11/2018
(1)
Manual SIMOTICS T-1FW6 naturally cooled built-in torque motors for SINAMICS S120
07/2017, Configuration Manual, -, 6SN1197-0AE01-0BP3
01/15/2018
(1)
Manual SIMOTICS T-1FW6 built-in torque motors for SINAMICS S120
07/2017, Configuration Manual, -, 6SN1197-0AE00-0BP9 R1A
01/15/2018
(2)
Product note Technical documentation SIMOTICS
Regardless of which application you are dealing with, whether you are doing a quick search online for help for a current machine message during operation, you want to familiarize yourself with a product, or you would like to compile your individual documentation: You will find the right current editions of the technical document. in electronic form, on data carriers, and printed.
12/22/2017
(9)
Product note SINAMICS & SIMOTICS S/M/L/T Motion Control Motors: Discontinuation of the KTY84-130 temperature sensor
Discontinuation of the KTY84-130 temperature sensor / Impact on SIMOTICS motors for Motion Control, motor spindles (Fa. Weiss) SINAMICS, SINUMERIK, SIMOTION
10/16/2017
(4)
Manual Naturally cooled SIMOTICS T-1FW6 built-in torque motors
07/2017, Operating Instructions, -, 6SN1197-0AF02-0BP2
09/05/2017
(3)
07/2017, Operating Instructions, -, 6SN1197-0AF00-0BP3
08/31/2017
(1)
Product note Sales and delivery release: SIMOTICS T-1FW6 with Pt1000 temperature sensor
Effective July 1, 2017, the Pt1000 is being introduced as a replacement for the discontinued KTY84-130 temperature sensor for SIMOTICS T-1FW6.
07/17/2017
(0)
Certificate General Product Approval, UL, UL
Certificate of Compliance 20131111-E93429
05/05/2017
(0)
Product note SIMOTICS T -1FW6 built-in torque motors: Stator design modification
The design of the stators for the SIMOTICS T-1FW6 built-in torque motors with outer cooling jacket (1FW6090/1FW6130/1FW6150) is changing in terms of the casting cover.
03/15/2017
(0)
Product note SIMOTICS T-1FW6 built-in torque motors: Rotor design modification
The design of the rotors for the SIMOTICS T-1FW6 built-in torque motors is changing in terms of the version and color.
02/24/2017
(1)
Certificate China-RoHS, Manufacturer
Statement to China-RoHS directive for Low-voltage products
08/22/2016
(0)
Certificate Declaration of Conformity, EC/EU-Declaration of Conformity, Manufacturer
EU Declaration of Conformity 664.20042.02
04/20/2016
(0)
Product note DOConCD V4.5 SP4 technical documentation for SINUMERIK in German and English
A new edition of the documentation collection DOConCD for SINUMERIK controllers 840D sl and 828D is available with immediate effect. Article number: 6FC5398-0AC10-1YA2 Delivery location: LZE
08/26/2015
(6)
FAQ SINAMICS, SIMOTICS: Discontinuation of the KTY84-130 temperature sensor
08/05/2015
(2)
FAQ SIMOTICS: Description of the order codes for the motor options
In Spares on Web, by entering the serial number, you can identify which options have been installed in a motor, and what these mean.
07/22/2015
(2)
FAQ Spare parts, repair services for SINUMERIK, SINAMICS
SINUMERIK, SINAMICS, SIMODIRVE, SIMOVERT, MASTERDRIVES, MICROMASTER, COMBIMASTER, POSMO, SIMOTION, SIMOTICS
04/24/2015
(2)
FAQ SIMOTICS T - 1FW6: Installation of the built-in torque motors
Summary: More detailed information on the installation of these motors is provided in the Configuration Manual. ...
01/23/2015
(0)
Product note SIMOTICS T 1FW6 built-in torque motors: Changed rotor design
On SIMOTICS T  1FW6 built-in torque motors, the rotor design has been changed regarding the inner surface and the color. ...
06/24/2014
(0)
1
