Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products
My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
Thumbnail
1FW6150-8RA15-0AA0
TORQUE MOTOR, ROTOR, DIAM. 230MM, 190MM
SIMOTICS T rotor for motor 1FW6150-0.B15-....; Diameter 230 mm; Length 190 mm; when using the direct motors in fork heads for machine tools or robots a license for the US patent US5584621 and the corresponding worldwide property rights may be required
  • Save filter
  • Load filter
  • e-mail on update
23
Entries
Filtered by
1FW6150-8RA15-0AA0
Entries per page: 20 50 100
1
2
Certificate General Product Approval, CCC
China Compulsory Product Certificate 562-13-DFC
05/07/2021
(1)
Manual SIMOTICS T-1FW6 external rotor built-in torque motors
12/2020, Operating Instructions, -, A5E49196960B AB
03/11/2021
(0)
Certificate Declaration of Conformity, EC/EU-Declaration of Conformity, Manufacturer
EU - Declaration of Conformity 664.20042.08
09/14/2020
(0)
Manual SIMOTICS T-1FW6 High Speed built-in torque motors
09/2019, Operating Instructions, -, 6SN1197-0AF04-0BP2
04/06/2020
(0)
Manual SIMOTICS T-1FW6 High Speed built-in torque motors for SINAMICS S120
01/2020, Configuration Manual, -, 6SN1197-0AE03-0BP3
04/06/2020
(0)
FAQ Where can you find data sheets, dimension sheets, CAD data, 2/3-D views of the SIMOTICS S, M, L, T motors?
01/30/2020
(4)
Product note SINAMICS & SIMOTICS S/M/L/T Motion Control Motors: Discontinuation of the KTY84-130 temperature sensor
Discontinuation of the KTY84-130 temperature sensor / Impact on SIMOTICS motors for Motion Control, motor spindles (Fa. Weiss) SINAMICS, SINUMERIK, SIMOTION
08/07/2019
(6)
Product note Technical documentation SIMOTICS
Regardless of which application you are dealing with, whether you are doing a quick search online for help for a current machine message during operation, you want to familiarize yourself with a product, or you would like to compile your individual documentation: You will find the right current editions of the technical document. in electronic form, on data carriers, and printed.
10/29/2018
(13)
Certificate Test Certificates, Declaration of the Compliance with the order, Manufacturer
Certificate of compliance with the order „type 2.1“ 2.1
07/06/2018
(3)
Manual SIMOTICS T-1FW6 naturally cooled built-in torque motors for SINAMICS S120
07/2017, Configuration Manual, -, 6SN1197-0AE01-0BP3
01/15/2018
(1)
Manual SIMOTICS T-1FW6 built-in torque motors for SINAMICS S120
07/2017, Configuration Manual, -, 6SN1197-0AE00-0BP9 R1A
01/15/2018
(2)
Manual Naturally cooled SIMOTICS T-1FW6 built-in torque motors
07/2017, Operating Instructions, -, 6SN1197-0AF02-0BP2
09/05/2017
(3)
07/2017, Operating Instructions, -, 6SN1197-0AF00-0BP3
08/31/2017
(1)
Certificate General Product Approval, UL, UL
Certificate of Compliance 20131111-E93429
05/05/2017
(0)
Product note SIMOTICS T -1FW6 built-in torque motors: Stator design modification
The design of the stators for the SIMOTICS T-1FW6 built-in torque motors with outer cooling jacket (1FW6090/1FW6130/1FW6150) is changing in terms of the casting cover.
03/15/2017
(0)
Product note SIMOTICS T-1FW6 built-in torque motors: Rotor design modification
The design of the rotors for the SIMOTICS T-1FW6 built-in torque motors is changing in terms of the version and color.
02/24/2017
(1)
Certificate China-RoHS, Manufacturer
Statement to China-RoHS directive for Low-voltage products
08/22/2016
(0)
EU Declaration of Conformity 664.20042.02
04/20/2016
(0)
FAQ SINAMICS, SIMOTICS: Discontinuation of the KTY84-130 temperature sensor
08/05/2015
(2)
FAQ SIMOTICS: Description of the order codes for the motor options
In Spares on Web, by entering the serial number, you can identify which options have been installed in a motor, and what these mean.
07/22/2015
(2)
1
2
