Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
Thumbnail
1LE1002-1DB23-4FA0-ZD10
LOW-VOLTAGE MOTOR, IEC
LOW-VOLTAGE MOTOR, IEC SQUIRREL-CAGE,SELF-VENTIL.,IP55 TEMP. CL. 155(F) ACC.TO 130(B) ALUMINIUM HOUSING, GENERAL LINE STANDARD EFFICIENCY IE1, 4POLE * FS160M * 11KW (50HZ) 12.6KW (60HZ) 3 AC 50HZ 400VD/690VY * 3 AC 60HZ 460VD * IM B5, IM V1 W/O PROT. COVER, IM V3, FLANGE: FF300 WITHOUT MOTOR PROTECTION TERMINAL BOX AT TOP, NO MOUNTING AT NDE POSSIBLE D10=EFF-NAME PLATE
  • Save filter
  • Load filter
  • email on update
47
Entries
Filtered by
Entries per page: 20 50 100
1
2
3
Product note SIMOTICS GP low-voltage motors 1LE10/1LE109/1FP10 SH63-160: Extension of the range of options with order code R18
Effective immediately, we are supplementing the range of options for SIMOTICS GP 1LE10/1LE109/1FP10 by following order code:
09/06/2018
(1)
Manual SIMOTICS Low-voltage motor Functionally safe encoder
09/2018, Compact Operating Instructions, A5E44248729A
08/27/2018
(0)
Manual SIMOTICS GP, SD, DP Low-Voltage Motors SH 63 ... 355
06/2018, Operating Instructions, A5E38483075A
06/28/2018
(40)
Catalog/Brochure Catalog D 81.1: Low-Voltage Motors SIMOTICS GP, SD, XP, DP
05/2018, Catalog, E86060-K5581-A111-B2-7600
06/27/2018
(19)
Manual Low-voltage motors SIMOTICS GP, SD, DP Safety instructions for SH 63 ... 355
06/2018, Readme, A5E43215508A, A5E43215508A
06/08/2018
(1)
Product note SIMOTICS GP/SD low-voltage motors 1LE10 SH63-71 / 1LE15 SH71: Extension of the range of options with order code D40
Effective immediately, we are supplementing the range of options for SIMOTICS GP 1LE10 SH63-71 and SIMOTICS SD 1LE15 SH71 by following order code:
05/16/2018
(0)
Certificate Declaration of Conformity, EC/EU-Declaration of Conformity, Manufacturer
EU Declaration of Conformity for Functional Safety Encoder A5E44451181A
04/19/2018
(0)
Product note SIMOTICS GP low-voltage motors 1LE10 SH63-71: Extension of the range of options with order codes D01 and D31
Effective immediately, we are supplementing the range of options for SIMOTICS GP 1LE10 SH63-71 by following order codes:
04/17/2018
(0)
Certificate General Product Approval, CSA, CSA
General Product Approval, CSA, CSA-S Certificate of Compliance 2413196
03/27/2018
(0)
Product note Documentation Center for customized documentation (SIMOTICS GP / SD / XP / DP / TN / FD Low-voltage motors)
Documentation Center for customized documentation (SIMOTICS GP / SD / XP / DP / TN / FD Low-voltage motors).
02/15/2018
(17)
Certificate Marine / Shipping, RINA / Registro Italiano Navale, RINA (Registro Italiano Navale)
Type Approval Certificate ELE009614XG
12/15/2017
(1)
Product note SIMOTICS GP AH63-200 low-voltage motors - release for sale and delivery: Extended options order codes for motor protection / Q options
Effective November 3, 2017, we are supplementing the range of options for SIMOTICS GP SH63-200 to include the following motor protection options.
12/11/2017
(1)
Certificate Marine / Shipping, DNV-GL, DNV-GL
Type Approval Certificate TAE00002AD
11/23/2017
(0)
Certificate Marine / Shipping, ABS / American Bureau of Shipping, ABS (American Bureau of Shipping)
Shipping Approval, ABS / American Bureau of Shipping, ABS (American Bureau of Shipping) 17-HG1652211-1-PDA-DUP
09/25/2017
(0)
Product note Sales and delivery release: Low-voltage motors SIMOTICS GP/SD 1LE10 SH63-71 / 1LE15 SH71 - option order code D47 for importing into the Eurasian customs union
09/21/2017
(0)
Product note SIMOTICS GP low-voltage motors 1LE10/1LE109/1FP10 FS63-132 with motor connectors: Extension of the range of options with order code R13
09/21/2017
(0)
Certificate General Product Approval, CCC, CQC
CCC, CQC 2015010401794723
02/21/2017
(1)
Shipping Approval, ABS / American Bureau of Shipping, ABS (American Bureau of Shipping) 14-HG1150629B
12/08/2016
(0)
Shipping Approval, ABS / American Bureau of Shipping, ABS (American Bureau of Shipping) 14-HG1150629A
12/08/2016
(0)
FAQ SINAMICS G110M: Overview of released motors for SINAMICS G110M for operation with SIMOGEAR
SIMOGEAR with SINAMICS G110M is an integrated drive system where geared motor and inverter are coupled mechanically but also thermally. Extending the range of motors for SINAMICS G110M requires thermal tests to prove proper operation of both components.
11/10/2016
(2)
1
2
3
Support to the statistics
With this function the IDs found are listed according to number (format .txt).
Generate list
Copy URL
Display page in new design
mySupport Cockpit
Related links
