Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
3RA1215-0DD15-1AV6
STARTER,REV,FB,S00,480 VAC,0.22 - 0.32A
Combination starter Reversing Fastbus mount,IEC SIRIUS Frame size S00,0.22-0.32a 480 VAC control voltage MSP aux-1 SPDT NO/NC Contactor auxiliary 2NO
  • Save filter
  • Load filter
  • email on update
41
Entries
Filtered by
3RA1215-0DD15-1AV6
Entries per page: 20 50 100
1
2
3
Certificate General Product Approval, EAC, IVANOVO-CERTIFICATE
EAC Certificate 3033
01/25/2018
(0)
Certificate Confirmation, Manufacturer
Radioactive Material in Products A0308
01/10/2018
(0)
Certificate For use in hazardous locations, ATEX-EC-Type-Examination-Certificate, DEKRA EXAM, DMT
ATEX-EG-Baumusterprüfbescheinigung 2194
12/06/2017
(0)
FAQ General: Import of EPLAN Electric P8 macros at edz-Format
This entry contains information about import EPLAN Electric P8 macros at edz-Format in EPLAN
12/04/2017
(7)
FAQ Safety characteristics - B10 values / failure rates of electromechanical SIRIUS products
This entry contains a list of the B10 values / failure rates of electromechanical SIRIUS products
06/22/2017
(29)
FAQ Permissibility of objects in the arc quenching spaces of 3RV circuit breakers
This article contains information on the permissibility of objects in the arc quenching spaces of circuit breakers.
02/08/2017
(2)
FAQ Increasing the endurance of fuseless load feeders by using larger contactors
This article contains information on the dynamic behavior of various types of contactors.
02/07/2017
(0)
FAQ Fuseless Load Feeders for a 3-phase load with rated operational voltage of 230V AC?
This entry contains information about Fuseless Load Feeders with rated operational voltage of 230V AC
11/29/2016
(4)
Chinese Quality Check Mark A0210
10/19/2016
(0)
Certificate Declaration of Conformity, EC/EU-Declaration of Conformity, Manufacturer
EU Declaration of Conformity 2114
09/27/2016
(1)
Certificate General Product Approval, UL, UL
UL Certificate of Compliance 20170123-E31519
02/20/2016
(0)
silicone-free A0126
11/12/2015
(0)
FAQ General: How to order the Product Catalog CA01
This FAQ describe how to order the Product Catalog CA01 on DVD.
07/20/2015
(3)
FAQ What must be taken into account for industrial controls when replacing a motor with an IE3 motor in an existing system?
This FAQ describe what is to consider when replacing an older motor with efficiency classes (eff3, eff2, eff1, or IE1, IE2) with a high-efficiency motor of efficiency class IE3.
06/16/2015
(3)
FAQ Certificates of origin, certificates of conformity, test reports, factory certificates for products from the distribution center in Amberg (Lieferzentrum Amberg (LZA)).
QUESTION: Who is responsible for issuing certificates of origin and certificates of conformity (EN 10204-2004-2-1), test reports and factory certificates for products from Amberg (LZA)? ...
01/26/2015
(3)
EAC-Certification 3036
09/01/2014
(0)
FAQ Achievable SIL with SIRIUS subsystems or subsystem elements that have a low demand rate according to IEC 61511
QUESTION: What Safety Integrity Level SIL is achievable with SIRIUS subsystems or subs ...
08/06/2014
(1)
08/06/2014
(0)
FAQ PFHD values in the informative annex K, Table K.1 of the ISO 13849-1 standard
QUESTION: ISO 13849-1 – Application Explanations How are the PFHD values in the i...
08/05/2014
(0)
FAQ Calculation of “non-electrotechnical components” permissible on the basis of IEC 62061
QUESTION: Why may “non-electrotechnical components”, e.g. valves, also be calculated on the basis of IEC 62061? ...
05/27/2014
(0)
1
2
3
