Siemens Industry Online Support
Siemens AG
Filter criteria for entries
Product tree
Clear all filters
Product
Search product
Entry type
Date
3RA1245-4HD44-1AM2
STARTER,REV,FB,S3,208 VAC,36 - 50A
Combination starter Reversing Fastbus mount,IEC SIRIUS Frame size S3,36- 50A 208 VAC control voltage MSP aux-1 SPDT NO/NC Contactor auxiliary -1NO Front mount
  • Save filter
  • Load filter
  • email on update
43
Entries
Filtered by
3RA1245-4HD44-1AM2
Entries per page: 20 50 100
1
2
3
FAQ Safety characteristics - B10 values / failure rates of electromechanical SIRIUS products
This entry contains a list of the B10 values / failure rates of electromechanical SIRIUS products
06/29/2018
Certificate General Product Approval, EAC, EAC
EAC Certificate RU C-DE.HA10.B.00061
05/23/2018
01/25/2018
Certificate Confirmation, Manufacturer
Radioactive Material in Products A0308
01/10/2018
12/08/2017
FAQ General: Import of EPLAN Electric P8 macros at edz-Format
This entry contains information about import EPLAN Electric P8 macros at edz-Format in EPLAN
12/04/2017
FAQ Permissibility of objects in the arc quenching spaces of 3RV circuit breakers
This article contains information on the permissibility of objects in the arc quenching spaces of circuit breakers.
02/08/2017
FAQ Increasing the endurance of fuseless load feeders by using larger contactors
This article contains information on the dynamic behavior of various types of contactors.
02/07/2017
FAQ Fuseless Load Feeders for a 3-phase load with rated operational voltage of 230V AC?
This entry contains information about Fuseless Load Feeders with rated operational voltage of 230V AC
11/29/2016
Chinese Quality Check Mark A0210
10/19/2016
Certificate General Product Approval, UL, UL
UL Certificate of Compliance 20170123-E31519
02/20/2016
11/12/2015
FAQ General: How to order the Product Catalog CA01
This FAQ describe how to order the Product Catalog CA01 on DVD.
07/20/2015
FAQ What must be taken into account for industrial controls when replacing a motor with an IE3 motor in an existing system?
This FAQ describe what is to consider when replacing an older motor with efficiency classes (eff3, eff2, eff1, or IE1, IE2) with a high-efficiency motor of efficiency class IE3.
06/16/2015
FAQ Certificates of origin, certificates of conformity, test reports, factory certificates for products from the distribution center in Amberg (Lieferzentrum Amberg (LZA)).
QUESTION: Who is responsible for issuing certificates of origin and certificates of conformity (EN 10204-2004-2-1), test reports and factory certificates for products from Amberg (LZA)? ...
01/26/2015
09/01/2014
08/06/2014
FAQ Achievable SIL with SIRIUS subsystems or subsystem elements that have a low demand rate according to IEC 61511
QUESTION: What Safety Integrity Level SIL is achievable with SIRIUS subsystems or subs ...
08/06/2014
1
2
3
Support to the statistics
With this function the IDs found are listed according to number (format .txt).
Generate list
Copy URL
View this page in new design
mySupport Cockpit
Related links
