Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
Thumbnail
3RA2220-0JB23-0AK6
STARTER REV S0 0.7-1A 120VAC SCREW
Fuseless motor starter Reversing operation 600VAC Size S0 0.7-1A 110/120VAC 50/60HZ screw connection For 35 mm rail-mounting Type of coordination 2 IQ = 150 KA Also full fills type Of coordination 1 1NO+1NC (per contactor)
  • Save filter
  • Load filter
  • email on update
33
Entries
Filtered by
3RA2220-0JB23-0AK6
Entries per page: 20 50 100
1
2
Certificate General Product Approval, EAC, IVANOVO-CERTIFICATE
EAC Certificate 3033
01/25/2018
(0)
Certificate Confirmation, Manufacturer
Radioactive Material in Products A0308
01/10/2018
(0)
FAQ General: Import of EPLAN Electric P8 macros at edz-Format
This entry contains information about import EPLAN Electric P8 macros at edz-Format in EPLAN
12/04/2017
(7)
FAQ Safety characteristics - B10 values / failure rates of electromechanical SIRIUS products
This entry contains a list of the B10 values / failure rates of electromechanical SIRIUS products
06/22/2017
(29)
FAQ Increasing the endurance of fuseless load feeders by using larger contactors
This article contains information on the dynamic behavior of various types of contactors.
02/07/2017
(0)
FAQ Fuseless Load Feeders for a 3-phase load with rated operational voltage of 230V AC?
This entry contains information about Fuseless Load Feeders with rated operational voltage of 230V AC
11/29/2016
(4)
Chinese Quality Check Mark A0210
10/19/2016
(0)
Confirmation IEC 60947, Annex Q, Category B 3335
05/18/2016
(0)
silicone-free A0127
11/12/2015
(0)
FAQ General: How to order the Product Catalog CA01
This FAQ describe how to order the Product Catalog CA01 on DVD.
07/20/2015
(3)
FAQ What must be taken into account for industrial controls when replacing a motor with an IE3 motor in an existing system?
This FAQ describe what is to consider when replacing an older motor with efficiency classes (eff3, eff2, eff1, or IE1, IE2) with a high-efficiency motor of efficiency class IE3.
06/16/2015
(3)
FAQ Certificates of origin, certificates of conformity, test reports, factory certificates for products from the distribution center in Amberg (Lieferzentrum Amberg (LZA)).
QUESTION: Who is responsible for issuing certificates of origin and certificates of conformity (EN 10204-2004-2-1), test reports and factory certificates for products from Amberg (LZA)? ...
01/26/2015
(3)
Product note Delivery release: Addition of size S2 contactors to the SIRIUS modular system
SIRIUS Innovations size S2 is the further development of the SIRIUS modular system up to 37kW with its wide portfolio of switching, protection and monitoring devices, load feeders, and function modules. ...
10/20/2014
(1)
EAC-Certification 3036
09/01/2014
(0)
FAQ Achievable SIL with SIRIUS subsystems or subsystem elements that have a low demand rate according to IEC 61511
QUESTION: What Safety Integrity Level SIL is achievable with SIRIUS subsystems or subs ...
08/06/2014
(1)
08/06/2014
(0)
FAQ PFHD values in the informative annex K, Table K.1 of the ISO 13849-1 standard
QUESTION: ISO 13849-1 – Application Explanations How are the PFHD values in the i...
08/05/2014
(0)
FAQ Calculation of “non-electrotechnical components” permissible on the basis of IEC 62061
QUESTION: Why may “non-electrotechnical components”, e.g. valves, also be calculated on the basis of IEC 62061? ...
05/27/2014
(0)
FAQ General: Is it mandatory to switch all phases of a 3-phase load?
QUESTION: Is it allowed to switch only 2 phases of a 3-phase load? ...
05/20/2014
(0)
FAQ Regulation for protecting switching devices against overload and short-circuits
QUESTION: How must switching devices be protected against overload and short-circui ...
05/19/2014
(0)
1
2
