Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
3SE2230-7V
POS.SWITCH MOLDED PLAST./2NO ROD ACTUAT.
POSITION SWITCH MOLDED PLASTIC DEGREE OF PROT.IP65,EN 50 041, SLOW ACTION CONTACTS 2N0, ROD ACTUATOR, ALUMINIUM ROD, 1 X M20 X 1.5
  • Save filter
  • Load filter
  • email on update
44
Entries
Filtered by
3SE2230-7V
Entries per page: 20 50 100
1
2
3
Certificate Marine / Shipping, ABS / American Bureau of Shipping, ABS (American Bureau of Shipping)
Certificate of Design Assessment 03-HG395356-PDA
01/11/2018
(0)
Certificate Confirmation, Manufacturer
Radioactive Material in Products A0308
01/10/2018
(0)
Certificate Marine / Shipping, RINA / Registro Italiano Navale, RINA (Registro Italiano Navale)
Type Approval Certificate ELE360217XG
01/09/2018
(0)
FAQ General: Import of EPLAN Electric P8 macros at edz-Format
This entry contains information about import EPLAN Electric P8 macros at edz-Format in EPLAN
12/04/2017
(7)
FAQ Bypassing safety functions with a key-operated switch in the sensor or actuator circuit
This entry provides information on bypassing a safety function with a key-operated switch
08/21/2017
(2)
Chinese Quality Check Mark A0210
10/19/2016
(0)
Certificate Declaration of Conformity, EC/EU-Declaration of Conformity, Manufacturer
EU-Declaration of Conformity 2371
04/20/2016
(0)
Certificate General Product Approval, CCC, CQC
CCC certificate 2003010305058617
04/07/2016
(0)
FAQ Reductions for command devices 3SB1 / 3SB2 / 3SB3 / 3SU1 and position switches 3SE2 / 3SE3 / 3SE5 when installed at altitudes of between 2000 and 5000 m above sea level
This FAQ contain the statements for reduction the voltage and current depend on the sea level.
02/15/2016
(2)
FAQ Actuator coding level in accordance with DIN EN ISO 14119
This FAQ describe which coding level according ISO 14119 can be reached by the Safety positions switches with Solenoid interlocking; the Safety positions switches with separate actuator and the non-contact safety switches.
09/24/2015
(0)
FAQ General: How to order the Product Catalog CA01
This FAQ describe how to order the Product Catalog CA01 on DVD.
07/20/2015
(3)
FAQ 3SE / 3SF position switches Hysteresis values when used in safety controllers
This FAQ describe the hysteresis for slow-action and snap-action contacts
06/24/2015
(1)
FAQ Certificates of origin, certificates of conformity, test reports, factory certificates for products from the distribution center in Amberg (Lieferzentrum Amberg (LZA)).
QUESTION: Who is responsible for issuing certificates of origin and certificates of conformity (EN 10204-2004-2-1), test reports and factory certificates for products from Amberg (LZA)? ...
01/26/2015
(3)
FAQ Achievable SIL with SIRIUS subsystems or subsystem elements that have a low demand rate according to IEC 61511
QUESTION: What Safety Integrity Level SIL is achievable with SIRIUS subsystems or subs ...
08/06/2014
(1)
08/06/2014
(0)
FAQ PFHD values in the informative annex K, Table K.1 of the ISO 13849-1 standard
QUESTION: ISO 13849-1 – Application Explanations How are the PFHD values in the i...
08/05/2014
(0)
FAQ Calculation of “non-electrotechnical components” permissible on the basis of IEC 62061
QUESTION: Why may “non-electrotechnical components”, e.g. valves, also be calculated on the basis of IEC 62061? ...
05/27/2014
(0)
FAQ General: Is it mandatory to switch all phases of a 3-phase load?
QUESTION: Is it allowed to switch only 2 phases of a 3-phase load? ...
05/20/2014
(0)
FAQ Regulation for protecting switching devices against overload and short-circuits
QUESTION: How must switching devices be protected against overload and short-circui ...
05/19/2014
(0)
FAQ Pulling forces for conductors with Cage Clamp connection technology
QUESTION: What pulling forces apply for round copper conductors that are connected to ...
05/13/2014
(1)
1
2
3
