Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
3SE3100-1B-ZA01
POSITION SWITCH, METAL-ENCLOSED
POSITION SWITCH, METAL-ENCLOSED SNAP-ACTION CONTACTS 1NO+1NC PLUNGER WITH INCREASED CORROSION PROTECTION
  • Save filter
  • Load filter
  • email on update
26
Entries
Filtered by
3SE3100-1B-ZA01
Entries per page: 20 50 100
1
2
FAQ Diagnostic coverage level to be specified and achievable safety integrity level for subsystems or SRP/CS with electromechanical components
This entry provides information on the diagnostic coverage level.
09/28/2018
(4)
FAQ General: Import of EPLAN Electric P8 macros at edz-Format
This entry contains information about import EPLAN Electric P8 macros at edz-Format in EPLAN
12/04/2017
(7)
FAQ Power losses / contact resistance for 3SB1 / 3SB2 / 3SB3 / 3SE3 / 3SE5 / 3SU1
This entry contains information about contact resistance for 3SB1 / 3SB2 / 3SB3 / 3SE3 / 3SE5 / 3SU1 units
02/24/2017
(0)
FAQ Reductions for command devices 3SB1 / 3SB2 / 3SB3 / 3SU1 and position switches 3SE2 / 3SE3 / 3SE5 when installed at altitudes of between 2000 and 5000 m above sea level
This FAQ contain the statements for reduction the voltage and current depend on the sea level.
02/15/2016
(2)
FAQ Actuator coding level in accordance with DIN EN ISO 14119
This FAQ describe which coding level according ISO 14119 can be reached by the Safety positions switches with Solenoid interlocking; the Safety positions switches with separate actuator and the non-contact safety switches.
09/24/2015
(0)
FAQ General: How to order the Product Catalog CA01
This FAQ describe how to order the Product Catalog CA01 on DVD.
07/20/2015
(3)
FAQ 3SE / 3SF position switches Hysteresis values when used in safety controllers
This FAQ describe the hysteresis for slow-action and snap-action contacts
06/24/2015
(1)
FAQ Certificates of origin, certificates of conformity, test reports, factory certificates for products from the distribution center in Amberg (Lieferzentrum Amberg (LZA)).
QUESTION: Who is responsible for issuing certificates of origin and certificates of conformity (EN 10204-2004-2-1), test reports and factory certificates for products from Amberg (LZA)? ...
01/26/2015
(3)
08/06/2014
(0)
FAQ Achievable SIL with SIRIUS subsystems or subsystem elements that have a low demand rate according to IEC 61511
QUESTION: What Safety Integrity Level SIL is achievable with SIRIUS subsystems or subs ...
08/06/2014
(1)
FAQ PFHD values in the informative annex K, Table K.1 of the ISO 13849-1 standard
QUESTION: ISO 13849-1 – Application Explanations How are the PFHD values in the i...
08/05/2014
(0)
FAQ Calculation of “non-electrotechnical components” permissible on the basis of IEC 62061
QUESTION: Why may “non-electrotechnical components”, e.g. valves, also be calculated on the basis of IEC 62061? ...
05/27/2014
(0)
FAQ General: Is it mandatory to switch all phases of a 3-phase load?
QUESTION: Is it allowed to switch only 2 phases of a 3-phase load? ...
05/20/2014
(0)
FAQ Regulation for protecting switching devices against overload and short-circuits
QUESTION: How must switching devices be protected against overload and short-circui ...
05/19/2014
(0)
FAQ Pulling forces for conductors with Cage Clamp connection technology
QUESTION: What pulling forces apply for round copper conductors that are connected to ...
05/13/2014
(1)
FAQ Fuses and miniature circuit breakers for the short-circuit protection of auxiliary contacts
QUESTION: What are the consequences if the short-circuit protection of auxiliary co ...
05/08/2014
(0)
FAQ Behaviour of Low-Voltage switchgear under conditions of very low air pressure or vacuum
QUESTION: What is the behaviour of Low-Voltage switchgear under conditions of very ...
04/04/2014
(1)
FAQ General: Temperature behavior of Low-Voltage Switchgear inside the control cabinet
QUESTION: What is the maximum permissible temperature on the plastic surface and connections of Low-Voltage Switchgear? ...
07/05/2013
(0)
FAQ General: Utilization categories of contactors, contactor relays and auxiliary contacts
QUESTION: Where can I find detailed information on utilization categories according IEC 60947-4-1, 3, 5-1 of contactors, contactor relays and auxiliary contacts? ...
06/18/2013
(0)
FAQ General: NOM approval mark on the Siemens Industrial Control products
QUESTION: What means the NOM marking on the Siemens industrial control products? ...
06/13/2013
(1)
1
2
