Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products
My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
Thumbnail
3SE5114-1CD02-1AF3
(EAN: 4011209692794 / UPC: 754554954417)
BASE SWITCH FOR
position switch metal enclosure 40 mm according to EN 50041, 1 NO/1 NC quick action contacts, with 2 LEDs, yellow/green, 24 V DC, roller plunger with stainless steel roller 13 mm pin assignment: Pin1=21, Pin2=22 Pin3=13 and LED green, Pin4=14 and LED yellow, Pin5=ground LED
  • Save filter
  • Load filter
  • e-mail on update
65
Entries
Filtered by
3SE5114-1CD02-1AF3
Entries per page: 20 50 100
1
2
3
4
Certificate Test Certificates, Type Test Certificates/Test Report
Type Test Certificate ( according Product-Standards ) 2812
09/10/2021
(0)
Catalog/Brochure Brochure - Sensing with SIRIUS 3SE Position and Safety Switches
03/2012, Brochure, SICP-B10007-00-7600
09/01/2021
(0)
Manual Application Manual - SIRIUS Safety Integrated
07/2021, Application Manual, A5E03752040020A/RS-AJ/009, 3ZX1012-0SK11-1AC1
07/28/2021
(72)
Certificate Declaration of Conformity, UK Declaration of Conformity, Manufacturer
UK Declaration of Conformity U2867
07/28/2021
(0)
Certificate Declaration of Conformity, EC/EU-Declaration of Conformity, Manufacturer
EU Declaration of Conformity 2867
07/28/2021
(0)
Manual Configuration Manual - SIRIUS 3SE5 / 3SF1 position switches and 3SE66 / 3SE67 magnetically operated switches
05/2021, Configuration Manual, NEB334869902000/RS-AD/005
05/26/2021
(7)
FAQ Safety characteristics - B10 values / failure rates of electromechanical SIRIUS and SENTRON products
This entry contains a list of the B10 values / failure rates of electromechanical SIRIUS and SENTRON products
05/05/2021
(32)
Catalog/Brochure Catalog – Related Catalogs – Opening information - Introduction (Chapters 00 and 1 out of IC 10 • 2021)
04/2021, Catalog
03/30/2021
(0)
Catalog/Brochure Catalog IC 10 • 2021 - SIRIUS Industrial Controls
04/2021, Catalog, E86060-K1010-A101-B2-7600
03/30/2021
(24)
Catalog/Brochure Catalog – Power Supply - Appendix - Selection and ordering at Siemens (Chapters 15 and 16 out of IC 10 • 2021)
04/2021, Catalog
03/30/2021
(0)
Catalog/Brochure Catalog - Position and Safety Switches (Chapter 12 out of IC 10 • 2021)
04/2021, Catalog
03/30/2021
(0)
Certificate Confirmation, Manufacturer
Material Declaration "Green Passport" A0434
03/30/2021
(0)
RoHS Compliance A0448
03/26/2021
(0)
Material Documentation A0451
03/08/2021
(0)
Certificate General Product Approval, CCC, Manufacturer
CCC Self Declaration 2020970305002249
11/07/2020
(0)
Certificate General Product Approval, EAC, EAC
EAC Certificate RU C-DE.A07.B.01025/20
06/30/2020
(0)
EAC Certificate RU C-DE.MIO62.B.00642/19
08/27/2019
(0)
Application example Monitoring a protective door up to PL e / SIL 3 with a fail-safe S7-1500 controller
To prevent access to the danger range of a machine, a protective door is installed. The machine can only be started, if the protective door is closed. If the protective door is opened during operation or if an error is detected, the machine will be shut down safely.
08/15/2019
(6)
Application example Protective door with spring-loaded interlocking with an S7-1500
To prevent access to the hazard zone of a machine during operation, a protective door is installed and the position of the protective door is monitored. Since overrunning machine components may cause hazards, the protective door is interlocked and can only be opened after the machine is in standstill.
08/15/2019
(6)
Modular design for all applications
08/02/2019
(1)
1
2
3
4
