Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products
My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
Thumbnail
3SE5132-0PJ01
POS. SWITCH EN50041 PLASTIC, TWIST LEVER
Position switch Plastic enclosure 40 mm Twist lever, according to EN 50041 Device connection 1 x (M20 x 1.5) 2 NO/1 NC slow-action contacts Rotary actuator right/left adjustable, Metal lever 27 mm long and plastic roller 19 mm
  • Save filter
  • Load filter
  • e-mail on update
59
Entries
Filtered by
3SE5132-0PJ01
Entries per page: 20 50 100
1
2
3
Catalog/Brochure Brochure - Sensing with SIRIUS 3SE Position and Safety Switches
03/2012, Brochure, SICP-B10007-00-7600
09/01/2021
(0)
Manual Application Manual - SIRIUS Safety Integrated
07/2021, Application Manual, A5E03752040020A/RS-AJ/009, 3ZX1012-0SK11-1AC1
07/28/2021
(72)
Certificate Declaration of Conformity, UK Declaration of Conformity, Manufacturer
UK Declaration of Conformity U2867
07/28/2021
(0)
Certificate Declaration of Conformity, EC/EU-Declaration of Conformity, Manufacturer
EU Declaration of Conformity 2867
07/28/2021
(0)
Manual Configuration Manual - SIRIUS 3SE5 / 3SF1 position switches and 3SE66 / 3SE67 magnetically operated switches
05/2021, Configuration Manual, NEB334869902000/RS-AD/005
05/26/2021
(7)
FAQ Safety characteristics - B10 values / failure rates of electromechanical SIRIUS and SENTRON products
This entry contains a list of the B10 values / failure rates of electromechanical SIRIUS and SENTRON products
05/05/2021
(32)
Catalog/Brochure Catalog – Related Catalogs – Opening information - Introduction (Chapters 00 and 1 out of IC 10 • 2021)
04/2021, Catalog
03/30/2021
(0)
Catalog/Brochure Catalog IC 10 • 2021 - SIRIUS Industrial Controls
04/2021, Catalog, E86060-K1010-A101-B2-7600
03/30/2021
(24)
Catalog/Brochure Catalog – Power Supply - Appendix - Selection and ordering at Siemens (Chapters 15 and 16 out of IC 10 • 2021)
04/2021, Catalog
03/30/2021
(0)
Catalog/Brochure Catalog - Position and Safety Switches (Chapter 12 out of IC 10 • 2021)
04/2021, Catalog
03/30/2021
(0)
Certificate Confirmation, Manufacturer
Material Declaration "Green Passport" A0434
03/30/2021
(0)
RoHS Compliance A0448
03/26/2021
(0)
Material Documentation A0451
03/08/2021
(0)
Certificate General Product Approval, CCC, Manufacturer
CCC Self Declaration 2020970305002249
11/07/2020
(0)
Certificate General Product Approval, EAC, EAC
EAC Certificate RU C-DE.A07.B.01025/20
06/30/2020
(0)
EAC Certificate RU C-DE.MIO62.B.00642/19
08/27/2019
(0)
Application example Monitoring a protective door up to PL e / SIL 3 with a fail-safe S7-1500 controller
To prevent access to the danger range of a machine, a protective door is installed. The machine can only be started, if the protective door is closed. If the protective door is opened during operation or if an error is detected, the machine will be shut down safely.
08/15/2019
(6)
Application example Protective door with spring-loaded interlocking with an S7-1500
To prevent access to the hazard zone of a machine during operation, a protective door is installed and the position of the protective door is monitored. Since overrunning machine components may cause hazards, the protective door is interlocked and can only be opened after the machine is in standstill.
08/15/2019
(6)
Modular design for all applications
08/02/2019
(1)
Catalog/Brochure Brochure - Electrical components for the railway industry
04/05/2019
(0)
1
2
3
