Siemens Industry Online Support
Siemens AG
Filter criteria for entries
All Products My Products
Product tree
Clear all filters
Product
Search product
Entry type
Date
Thumbnail
3SE5214-0KC05-1AE1
SIRIUS POSITION SWITCH;
Position switch Metal enclosure according to EN 50047, 31 mm Device connection 1 x (M20 x 1.5) 1 NO/2 NC slow-action contacts with M12 connector, 5-pole 2 NC connected Pin assignment: Pin1=21, Pin2=22 Pin3=31, Pin4=32, Pin5=PE max. 250 V and 4 A with plunger
  • Save filter
  • Load filter
  • email on update
54
Entries
Filtered by
3SE5214-0KC05-1AE1
Entries per page: 20 50 100
1
2
3
FAQ Safety characteristics - B10 values / failure rates of electromechanical SIRIUS products
This entry contains a list of the B10 values / failure rates of electromechanical SIRIUS products
06/29/2018
(31)
Manual Configuration Manual - SIRIUS 3SE5/3SF1/3SE66/3SE67 position switches
06/2018, Configuration Manual, NEB334869902000/RS-AC/004, 3ZX1012-0SE50-1AC1
06/22/2018
(3)
FAQ B10 values electro-mechanical command and signaling devices, position and safety switches
This entry provides information on the B10 values of electro-mechanical command and signaling devices, position and safety switches.
02/21/2018
(0)
Certificate General Product Approval, CCC, CQC
CCC Certificate 2007010305260238
01/16/2018
(0)
Certificate Confirmation, Manufacturer
Radioactive Material in Products A0308
01/10/2018
(0)
Certificate General Product Approval, UL, UL
UL Certificate of Compliance 20130115-E44653
12/20/2017
(0)
Certificate General Product Approval, CSA, CSA
Certificate of Compliance CoC 165071-1885692
12/20/2017
(0)
Manual Catalog IC 10 • 2018 - SIRIUS Industrial Controls
12/11/2017
(1)
FAQ General: Import of EPLAN Electric P8 macros at edz-Format
This entry contains information about import EPLAN Electric P8 macros at edz-Format in EPLAN
12/04/2017
(7)
Application example SIRIUS Safety Integrated Application Manual
This documentation provides an insight into the fundamental safety requirements in the manufacturing industry.
10/24/2017
(10)
Manual Application Manual - SIRIUS Safety Integrated
08/2017, Application Manual, A5E03752040020A/RS-AF/006, 3ZX1012-0SK11-1AC1
09/26/2017
(56)
Application example Protective door with spring-loaded interlocking with an S7-1500
To prevent access to the hazard zone of a machine during operation, a protective door is installed and the position of the protective door is monitored. Since overrunning machine components may cause hazards, the protective door is interlocked and can only be opened after the machine is in standstill.
09/08/2017
(4)
FAQ Bypassing safety functions with a key-operated switch in the sensor or actuator circuit
This entry provides information on bypassing a safety function with a key-operated switch
08/21/2017
(2)
Application example Monitoring a protective door up to PL e / SIL 3 with a fail-safe S7-1500 controller
To prevent access to the danger range of a machine, a protective door is installed. The machine can only be started, if the protective door is closed. If the protective door is opened during operation or if an error is detected, the machine will be shut down safely.
08/18/2017
(6)
FAQ Assessment of the effect of wear and tear on the service life of electromechanical devices
This entry contains information on the effect of wear and tear on the service life of electromechanical devices.
05/31/2017
(5)
FAQ Power losses / contact resistance for 3SB1 / 3SB2 / 3SB3 / 3SE3 / 3SE5 / 3SU1
This entry contains information about contact resistance for 3SB1 / 3SB2 / 3SB3 / 3SE3 / 3SE5 / 3SU1 units
02/24/2017
(0)
Chinese Quality Check Mark A0210
10/19/2016
(0)
Manual Catalogue IC 90, 2016 - SIRIUS Appareillage Industriel
Language: FRENCH
10/04/2016
(0)
Certificate Declaration of Conformity, EC/EU-Declaration of Conformity, Manufacturer
EU Declaration of Conformity 2867
04/20/2016
(0)
FAQ Reductions for command devices 3SB1 / 3SB2 / 3SB3 / 3SU1 and position switches 3SE2 / 3SE3 / 3SE5 when installed at altitudes of between 2000 and 5000 m above sea level
This FAQ contain the statements for reduction the voltage and current depend on the sea level.
02/15/2016
(2)
1
2
3
