Please wait...
Please wait...
Action not completed. Please select a lower amount of topics.
Close
My library
Search in
for
Index
Document: MDM - WinCC: Working with WinCC (11/2008, English)
Type of topic: Fact
Description of WinCC System Messages
Introduction
The system messages generated by the various WinCC modules are described below. You can integrate these messages into your message system using the "WinCC - System Messages" menu command.
Note
When you assign system messages to a user-defined message class, the message class must have the same properties as the system message class.
Note
You can obtain additional information on the system messages in the system message block "Comment" for the message.
WinCC system messages
Number
Error Message / Description
1000000
WCCRT:Error
1000001
WCCRT:Error loading the object engine
1000002
WCCRT:Channel could not be loaded
1000003
WCCRT:Tag - Violated lower limit
1000004
WCCRT:Tag value of the high limit is exceeded
1000005
WCCRT:Format error of tag
1000006
WCCRT:Scale error of tag
1000100
WCCRT:Drive error
1000200
WCCRT:Status
1000201
WCCRT:Object Engine was loaded
1000202
WCCRT:Runtime has been activated
1000203
WCCRT:Runtime has been deactivated
1000204
WCCRT:Connection not established
1000205
WCCRT:Connection established
1000206
WCCRT:Client connection established
1000207
WCCRT:Client connection disconnected
1000208
WCCRT:Client connection broken
1000209
WCCRT:Connection deleted
1000210
WCCRT:Connection modified
1000211
WCCRT:Connection reestablished
1000300
WCCRT:Driver state
1000800
PACKAGE:Import
1000801
PACKAGE:Export
1000802
PACKAGE:Delete
1000803
PACKAGE:New
1000804
PACKAGE:Reload
1000805
PACKAGE:DefaultServer
1000806
PACKAGE:Implicit update
1000807
PACKAGE:Update
1000900
PERFMON: is low
1000901
PERFMON: is OK
1000902
PERFMON: is high
1000903
PERFMON: is OK
1000904
PERFMON: is low
1000905
PERFMON: is OK
1000906
PERFMON: is high
1000907
PERFMON: is OK
1000908
PERFMON: is low
1000909
PERFMON: is OK
1000910
PERFMON: is high
1000911
PERFMON: is OK
1000912
PERFMON: Redundancy loss of the terminal adapter
1000913
PERFMON: Redundancy of the terminal adapter restored
1000914
PERFMON: Terminal adapter connected
1000915
PERFMON: Terminal adapter disconnected
1001000
PDLRT: General error
1001001
PDLRT: Operator action not active
1001002
PDLRT: Wrong picture format
1001003
PDLRT: Picture not found
1001004
PDLRT: No dynamic active in picture
1001005
PDLRT: Tag could not be written
1001006
PDLRT: Dynamic Actions not active
1002000
TLGRT: General error
1002001
TLGRT: Error during initialization
1002002
TLGRT: Error during loading of run-time data
1002003
TLGRT: Error during language switch
1002004
TLGRT: Error during access to database
1002005
TLGRT: Error during creation of run-time objects
1002006
TLGRT: Error during on-line configuration
1002007
TLGRT: Error in client/server environment
1002008
TLGRT: Error in memory management
1002009
TLGRT: Error compiling measured values
1002010
TLGRT: Error processing measured values
1002011
TLGRT: Error archiving measured values
1002012
TLGRT: Error in Format DLL
1002013
TLGRT: Error with user archive option
1002014
TLGRT: Error in process controlled archiving
1002015
TLGRT: Error in the API
1002016
TLGRT: Error with the application window
1002017
TLGRT: System error
1002018
TLGRT: Database queue overflow
1002019
TLGRT: Notification queue overflow
1002020
TLGRT: Norm DLL queue overflow - data is lost!
1002021
TLGRT: Problems with the connection to the central archive server.
1002022
TLGRT: The problem with the connection to the central archive server was fixed.
1003018
ALGRT:Message does not require acknowledgment.
An attempt was made to acknowledge a message that does not require acknowledgement.
1003019
ALGRT:Message has already been acknowledged
An attempt was made to acknowledge a message that has already been acknowledged.
1003020
ALGRT:Message class for the message not found
The message class associated with the message does not exist.
1003021
ALGRT:Message status cannot be processed
The message status (Came In, Went Out, Acknowledged, ...) could not be interpreted.
1003022
ALGRT:Message is locked
This message occurs if you attempt to trigger a locked message via the API.
1003023
ALGRT:Message date/time-stamp invalid
The date/time stamp from the AS could not be interpreted.
1003032
ALGRT:Message window template name unknown
This error occurs when a message window that was previously configured in the Graphics Design is deleted subsequently.
In the case of client/server projects, this message could also be triggered by a communication error in the network.
1003033
ALGRT:Message window could not be created
1003034
ALGRT:Message window data invalid
The configuration data are faulty.
1003048
ALGRT:Bit is outside the tag range.
For example, an attempt was made to trigger the 18th bit of a 16-bit tag.
1003049
ALGRT:No tag change
1003050
ALGRT:Message tag (bit) already occupied by a message
The bit of the message tag has already been interconnected to a message.
1003051
ALGRT:Acknowledge tag(bit) already used
The acknowledgement tag bit has already been interconnected to a message.
1003052
ALGRT:Status tag already occupied by message
The bit of the status tag has already been interconnected to a message.
1003053
ALGRT:Error during conversion of the variant data type
1003054
ALGRT:Message tag (bit) already occupied-->different type
1003055
ALGRT:Event tag or tag type invalid
The data type of the message tag is invalid. A tag with sign was used, for example.
1003056
ALGRT: Acknowledgment tag or tag type invalid
The data type of the acknowledgement tag is invalid. A tag with sign was used, for example.
1003057
ALGRT:Status tag or tag type invalid
The data type of the status tag is invalid. A tag with sign was used, for example.
1003058
ALGRT:Handle invalid
This error message can occur during accesses via the API.
1003059
ALGRT: Selection criteria invalid
1003060
ALGRT: Resources DLL for language not found
One of the language-dependent files is missing.
1003061
ALGRT:Error while creating the memory mapped file
This internal error indicates a problem involving the memory.
1003062
ALGRT:Error while creating the synchronization mechanism.
This error occurs when the operating system is overloaded.
1003063
ALGRT:Wrong parameter
1003064
ALGRT:Transfer buffer too small
1003065
ALGRT:This function is not available at this time
1003066
ALGRT:Format DLL send data cannot be evaluated.
1003067
ALGRT:Format DLL. Do not execute function
1003068
ALGRT:No message blocks in the report
Check the message sequence report.
1003069
ALGRT:Invalid log
1003070
ALGRT:Report printout is already active
An attempt was made to restart an active report.
1003071
ALGRT:Message system runtime <Server> not installed
The server reports that the project was activated without the runtime component of Alarm Logging.
1003072
ALGRT:Printout of the message report could not be started.
1003073
ALGRT:Printout of the short-term archive not started.
1003074
ALGRT:Printout of the sequence archive report not started.
1003075
ALGRT:Limit of Messages for Online Configuration exceeds.
The maximum number of messages that can be configured online (default setting is 600) has been exceeded.
1003076
NRMS7:Parameter error for S7 message frame
A parameter error has occurred on the interface to S7.
1003077
NRMS7:Parameter error for ALGRT
A parameter error has occurred on the interface to ALGRT.
1003078
NRMS7:Invalid parameter TLGRT
A parameter error has occurred on the interface to TLGRT.
1003079
NRMS7:Invalid process value blocks
The additional data of the messages are faulty.
1003080
NRMS7:Parameter error at AR_SEND
The structure of the AR-SEND user data is faulty.
1003081
NRMS7:General error
An internal error of unknown cause has occurred.
1003082
NRMS7:Message loss on the automation system
1003083
NRMS7:Link-up and update on PLC active
1003084
NRMS7:Link-up and update on PLC finished
1003085
NRMS7:System modification in RUN (CiR) active
1003086
NRMS7:System modification in RUN (CiR) inactive
1003087
NRMS7:Error while logging on to receive message
1003098
ALGRT:Message archiving overflow - messages will be lost
1003099
ALGRT:[Computer Name]:Locked messages [message number] [message text of locked message]
This message occurs when a message is locked.
1003100
ALGRT:[Computer Name]:Message [message number] unlocked [message text of unlocked message]
This message occurs when a message is unlocked.
1003101
ALGRT:Acknowledgement request for message [message number]  was issued
This message occurs when a message is acknowledged.
1003102
ALGRT:[Computer Name]:Message group [message group number] locked
This message occurs when a message group is locked.
1003103
ALGRT:[Computer Name]:Message group [message group number] unlocked
This message occurs when a message group is unlocked.
1003104
ALGRT:[Computer Name]:Alarm Message Archive Overflow ended - no more Alarms will be lost
1003105
ALGRT:[Computer Name]:alarm input queue reaches critical count
1003106
ALGRT:[Computer Name]:alarm input queue reaches uncritical count
1003107
ALGRT:[Computer Name]:Message [Message Number] hidden:@1%s@
1003108
ALGRT:[Computer Name]:Message [Message Number] shown:@1%s@
1003109
ALGRT:[Computer name]: The connection to the master was interrupted.
1003110
ALGRT:[Computer name]: Incomplete configuration data for message [message number] detected
1004000
RPTRT:General error
1004001
RPTRT:PRT_OUT-Folder full.
1004002
RPTRT:Spool-Folder full.
1004003
RPTRT:Report was not printed. PRT_OUT directory full
1004004
RPTRT:Report was not printed. Spool folder full
1004005
RPTRT:Message sequence report is reprinted.
1004006
1004007
RPTRT:Hardcopy was not printed. Spool folder full
1005000
TXTRT:General error
1005001
TXTRT:Error while logging off runtime applications.
1005002
TXTRT:Error during connection of the run-time applications.
1005003
TXTRT:Error during initialization of the MMF.
A memory error has occurred.
1005004
TXTRT:Error while loading the MMF.
Error during access to database.
1005005
TXTRT:Error while opening the MMF.
1005006
TXTRT:An error occurred while creating the Service window.
1005007
TXTRT:No language found.
1005008
TXTRT:Text ID not found.
The requested Text ID could not be found in the text library.
1005009
TXTRT:MMF Read access refused.
1005010
TXTRT:Language not found.
The requested language has not been configured in the text library.
1005011
TXTRT:Language table could not be opened.
Either the data are faulty or the table is locked in the database.
1005012
TXTRT:Text table could not be opened.
1005013
TXTRT:Invalid Language specified.
The Language ID specified is invalid.
1005014
TXTRT:DBConnect error
No connection to the database could be set up.
1006000
GSCRT:Error
1007000
SCRIPT:Overflow
Overload: either there are too many actions running in a cycle that is too small, or an action is suspended (endless loop, dialog output). All the other actions are in the queue and cannot be processed.
1007001
SCRIPT:Action error
One of the following errors has occurred:
  • Exception in the action (specific cause unknown)
  • Exception upon access to the return result (char* associated memory invalid)
  • Stack overflow upon execution of the action
  • The action contains a division by 0
  • The action contains an access to a non-existing symbol
  • The action contains an access violation
    In WinCC version 4.0 and higher, you can integrate the OnErrorExecute function in your script, which allows for a detailed analysis of errors.
1007002
SCRIPT:Overflow
Internal lists have overflowed.
1007003
SCRIPT:Connection error
The connection to the server is broken.
1007004
SCRIPT:Action error 1
The called function is not known. Check the spelling in the function call and the implementation of the function.
1007005
SCRIPT:Action error 2
This error can have several causes:
  • The action does not contain a P code. Recompile the action.
  • The function could not be loaded, for example, due to incorrect function name.
  • The type of the returned value of the function is invalid.
1007006
SCRIPT:Tag error
A requested tag was not supplied by WinCC Explorer within 10 seconds. Check the spelling of the tag name. In the case of external tags, there may be a communication problem between the WinCC Explorer and the PLC.
From WinCC version 4.0, you have the option to incorporate the OnErrorExecute function into your script, which allows for a detailed analysis of errors.
1007007
SCRIPT: Info
Additional information under "Diagnostics of WinCC / Runtime Monitoring for Actions".
1007009
SCRIPT:Error in Thread
1008000
USERT:Connection to chip card reader paused
1008001
USERT:Incorrect login name/password
1008002
USERT:Incorrect login name/password by chip card
1008003
USERT:Manual Login
1008004
USERT:Login by chipcard
1008005
USERT:Manual Logout
1008006
USERT:Logout by chipcard
1008007
USERT:Automatic Logout by timeout
1009000
LBMRT:Error
1010000
STRRT:Error
1010001
Storage:included for compatibility to earlier versions
1010002
1010003
1010004
1010005
1010006
1010007
1010008
1010101
CAS:Starts archive service
1010102
CAS:Archive service is running
1010103
CAS:Archive service could not be started, error
1010104
CAS:Stops archive service
1010105
CAS:Archive service could not be stopped, error
1010106
CAS:Media backup completed successfully
1010107
CAS:Backup process failed, error
1010108
CAS:Backup medium created
1010109
CAS:Backup medium closed
1010110
CAS:Backup connected
1010111
CAS:Backup connection failed, error
1010112
CAS:Backup disconnected
1010113
CAS:Backup disconnection failed, error
1010114
CAS:Import of archive started
1010115
CAS:Import of archive failed, error
1010116
CAS:Import of archive completed
1010117
CAS:Archive failed, error
1010118
CAS:Archive completed
1010119
CAS:Starts processing of archive
1010120
CAS:Data backup started
1010121
CAS:Data backup completed successfully
1010122
CAS: No symbolic name could be assigned to the physical server.
1010123
CAS: Caution, License not found: SIMATIC PCS7 StoragePlus Server. Long-term archiving deactivated
1010124
CAS: Archive cannot be verified.
1010130
StoragePlus: Directory cannot be created, error
1010131
StoragePlus: File cannot be moved, error
1011000
CSIG:Group display error at start up
1011001
CSIG:Group display hierarchy not updated
1011002
Group display: Connection fault
1011003
Group display: Tag does not exist
1011101
PTM: Error during start up
1011201
SSM: Error during start up
1011202
The fill level of the project drive is over 80%
1011203
The project was created with the wrong WinCC version
1012001
SYNC:Switched to master operation
1012002
SYNC:Cannot issue time message frame
1012003
SYNC:Time receipt service: Poor or failed signal
1012004
SYNC:Cannot receive time message frame
1012005
SYNC:Cannot receive any time message frame on redundant bus
1012006
SYNC:No time message frame. Switch to redundant device
1012007
SYNC:Can issue time message frame properly
1012008
SYNC:Time reception service functions properly
1012009
SYNC:Can receive time message frame properly
1012010
SYNC:Can receive time message frame properly on redundant bus
1012011
SYNC:Switched to slave operation
1012012
SYNC:Time synchronization deactivated
1012013
SYNC:Time synchronization activated
1012014
SYNC:DCF77 client service has failed
1012015
SYNC:DCF77 client service is working properly
1012016
SYNC:Device switched to master operation
1012017
SYNC:Device switched to slave operation
1012018
SYNC:Device cannot issue time message frame
1012019
SYNC:Device can issue time message frame properly
1012020
SYNC:Device sets local time
1012021
SYNC:LAN sync: Time synchronization fault on PC
1012022
SYNC:LAN sync: Time synchronization set on PC
1012023
SYNC:LAN sync: Time synchronization established with PC
1012024
SYNC:Configured device name for the time synchronization does not agree with PC installation
1012025
SYNC:LAN sync: Cannot acquire time from the connected WinCC server
1012026
SYNC:Time jump - switched to permanent slave mode
1012027
SYNC:Time jump - time synchronization permanently deactivated
1012028
SYNC:Time reception service not started
1012029
1012200
REDRT:Partner station has failed
1012201
REDRT:Partner station restarted
1012202
REDRT:Projects are not functionally identical
1012203
REDRT:Archive synchronization failed
1012204
REDRT:Internal error in Redundancy
1012205
REDRT:Connection to partner disturbed
1012206
REDRT:Connection to the partner has been reestablished
1012207
REDRT:Partner server - WinCC has not been started
1012208
REDRT:Archive synchronization starts
1012209
REDRT:Synchronization finished
1012210
REDRT:Tag Logging is being synchronized
1012211
REDRT:Tag Logging synchronization finished
1012212
REDRT:Alarm Logging is being synchronized
1012213
REDRT:Alarm Logging synchronization finished
1012214
REDRT:User Synchronization launched
1012215
REDRT:User Archive synchronization finished
1012216
REDRT:Synchronization was paused
1012217
REDRT:Partner Server-Project has not been activated
1012218
SWITCH:Client has been switched automatically
1012219
SWITCH:Client has been switched manually
1012220
REDRT:Synchronization is not ready for all User Archives
1012221
REDRT:Synchronization is ready for all User Archives
1012222
SWRED:Main connection disturbed
1012223
SWRED:Main connection operational
1012224
SWRED:Backup connection disturbed
1012225
SWRED:Backup connection operational
1012226
REDRT:Partner Server-Project has been activated
1012227
REDRT:Error: Partner computer is not a server
1012228
REDRT:CAS: Archive synchronization launched
1012229
REDRT: CAS: Archive synchronization finished
1012240
REDRT:RedundancyControl error triggered switching
1012241
REDRT:RedundancyControl: Switch to status
1012242
DELTALOADER:Delta loading was started
1012243
DELTALOADER:Delta loading ended
1012244
REDRT:Overload during Alarm Logging online update
1012245
REDRT:RedundancyControl: Loss of serial connection
1012246
REDRT:RedundancyControl: Serial connection reestablished
1012247
REDRT: OS server (standby) redundancy error
1012248
REDRT: OS server (standby) redundancy reestablished
1012250
AM:Archive database inconsistency possible
1012251
AM:Internal error
1012252
AM:Backup:Error on writing to backup path
1012253
AM:Backup:Insufficient storage space on destination drive
1012254
AM:No connection to WriteArchiveServer
1012255
AM:No connection to Microsoft Message Queue
1012256
AM:No connection to WinCC project
1012257
AM:No connection to the database
1012258
AM:No connection to text library
1012259
AM:Error on generating TagLogging data
1012260
AM:Error on generating AlarmLogging data
1012265
AM:Data base verification failed
1012301
CA:No access to SQL Server (loss of data possible)
1012348
AM:Insufficient free memory space on project drive
1012349
REDRT:RedundancyControl: Connection of network card (MAC) address lost
1012350
REDRT:RedundancyControl: Connection via network card (MAC) address established again
1012400
WEBRT:WebClient connection established
1012401
WEBRT:WebClient connection disconnected
See also
internal linkHow To Insert WinCC System Messages
  MDM - WinCC: Working with WinCC - 11/2008
##Ziel nicht verfügbar ....
# Dieses Topic befindet sich nicht in Ihrer Persönlichen Bibliothek...
My productions
Delete production
Do you really want to delete the production?
Settings
Standardized warnings:
Default language
Create folder
Here you have the option to create a new folder. You can instantly enter the file name in several languages.
Additional languages
Change language
The content is available in several languages. Please select one language.
Target language
Enter title in the target language
Now you have the option to localied this title.
_
Create export
Target format
Title
Author
It the author to be transferred to the generated document?
Are own contents to be exported?
Document language
Framework language
Insert images
Insert pdf documents
Notification
The contents of the following documents will be filled with the selected default language.
#Cookies nicht aktiviert
#Aktuell sind in Ihrem Browser Cookies deaktivert. Daher können Sie den My Documentation Manager nicht in vollem Umfang nutzen.
Edit user data close
Notiz erstellen
Create hyperlink topic
Here, you have the option to include hyperlinks in your documentation.
Up to 10 hyperlinks can be inserted for each hyperlink topic.
Each hyperlink can contain a display title and a description.
Topic title
Introduction
Hyperlink list
Add new hyperlink.
This topic was created by a user. SIEMENS AG assumes no liability for the contents of the linked websites.
Language
