(0)| 11/16/2022 11:44 AM | |
Posts: 2 Rating:
Hello dear I had problem with power supply module in S7-400H . The problem is as follows: CPU in rack 0 was run and CPU in rack 1 was stand by .the power supply module in rack 0 has been faulty and off. unfortunately CPU rack 0 has been stop and CPU rack 1 also has been stop so control is not changed to CPU rack 1 and process had been stop. could you give me more information that what happened ? I expect CPU in rack 1 can control the process and prevent from stop the process. power supply : 6ES7-407-0DA01-0AA0 CPU: 414-4HJ00-0AB0 V3.1.3 Thanks in advance mohammad khezri ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/16/2022 13:02:29New subject after splitting |
