8/14/2021 5:17 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating:
Hello, Do you mean to say you replaced 6SE7022-6EC51, 25.5 Amp Simovert masterdrive MC by 6SE7016-1TA51 6.1 Amp Simovert masterdrive MC ? Is it correct? 1. How you can replace 25 Amp drive by 6.1 Amp drive? 2. How you parameter rectifier & inverter unit in replacement case? Please check. |
8/16/2021 9:13 AM | |
Joined: 5/26/2020 Last visit: 8/8/2022 Posts: 2 Rating:
Yes, I made this replacement. Before the frequency converter 6SE7022-6EC51 was used, we used 6SE7016-1EA51-Z - this was originally installed on the equipment. Therefore, we made a replacement with 6SE7016-1TA51-Z. I replaced it with a different inverter using a tool assisted commissioning.Is it possible that some parameters are missing or the problem is in the hardware of the installed frequency converter?
