4/6/2009 11:14 PM | |
Posts: 271 Rating: (29) |
Hello Netforce, Since you're interested in Profibus signals, apparently you are working with the Simodrive 611U control units. Always consider using SimoCom U software for diagnostic purposes first. The enable signals are all on the main configuration screen and the bottom lefthand side have LED type indicators. Take a look at the Configuration Manual for the Simodrive 611U (www.automation.siemens.com/doconweb) and go to Section 5.6.2. This shows the enable signals for both velocity mode (i.e., n-set) and positioning mode in the control word STW1. This is your list of enable signals. Hope this helps... |
