12/5/2022 1:11 PM | |
Joined: 4/28/2015 Last visit: 8/26/2024 Posts: 3345 Rating:
Hi,
you need to edit the file with a text-editor in Linux, e.g.
Then save and close the file (Ctrl+X, Y, Enter) and restart node-red. As an alternative you can use WinSCP to open and change the file. Then you should be prompted for a user and password when opening node-red. There is an instruction we well from another user. Check the whole post, as with the second last image version the command to create the hashed password has changed. Best regards! |
