1/18/2012 1:34 PM | |
Joined: 4/30/2011 Last visit: 1/9/2022 Posts: 223 Rating: (4) |
pls see my file... whats wrong?!!!!
AttachmentProject1.zip (716 Downloads) |
1/18/2012 3:10 PM | |
Posts: 3037 Rating: (192)
Hello, See the screen. You have no constant value in the setting of your tag. see screen Properties --> Range You enter this in ---> Maximum = 32, Minimum = 27. Then you start the Runtime. You can see in the I/O field values from 27 between 32 when you use the slider. Tweety Attachmentscreens.zip (729 Downloads) |
1/18/2012 6:43 PM | |
nothing changed show me pls printscreen when color in I/O changed ?!)
1/19/2012 11:53 AM | |
Tks I know it Why need propertis "limit" and "color" in I/O Feild?!!!
1/19/2012 2:49 PM | |
Hello, You can choose the color and the limits there. If the color works, then you see easier if the limit is overrun. Tweety |
1/19/2012 3:24 PM | |
ha-ha soI'm talkingabout Itwholetopic -that the limitsdo not work anddoes not changecolor! This isBAG!!!!!!!!! |
1/20/2012 5:08 PM | |
fuh tks a lot
