10/4/2013 10:14 AM | |
Joined: 11/15/2006 Last visit: 5/7/2021 Posts: 1319 Rating: (174)
You should - at first - disable the automatic restart on Bluescreen, so you can see what the BSOD tells you. This is the first indication on what is causing the problem. See http://pcsupport.about.com/od/tipstricks/f/automatic-restart.htm Then, check the windows eventlogs for indications. Third, you should check whether there are any new drivers for your system available. |
Have Fun! |
