(0)| 5/9/2025 10:49 AM | |
Joined: 1/21/2013 Last visit: 1/11/2026 Posts: 4387 Rating:
Hi, Unfortunately, I believe this is a bug. You should create a support request to get it clarified with development. Hopefully, the fix will be part of the next update. Kind regards |
| 5/9/2025 12:20 PM | |
Joined: 12/9/2024 Last visit: 9/30/2025 Posts: 3 Rating:
Thank you! |
| 10/21/2025 8:31 AM | |
Joined: 5/22/2012 Last visit: 12/1/2025 Posts: 10 Rating:
Have you got any solution for this Problem? |
| 10/21/2025 11:56 AM | |
Hi Daniel L. PLP, Since it may take Bekim some time to read your post, here is my response. After doing some research, I found that, contrary to my initial assumption, this topic is not classified as a bug. Apparently, it is a known restriction of the unified panel that it does not yet support the minimum/maximum threshold value drop-down. Creating a support request will help clarify this topic for you. And it would be helpful for others, if you share the response you will get on this. Kind regards |
