(0)| 5/8/2025 12:38 PM | |
Joined: 12/6/2024 Last visit: 11/18/2025 Posts: 22 Rating:
hello guys, I also have a similar problem , I suppose, with this specific Library. I'm using a S7-1214 CPU to establish communication between my PLC and a FANUC R30i-B controller. At first I was able to send data to the FTP server of the Fanuc controller, after some time I wasn't able to send anything. only receive or delete files. I also get the erro 16#8604. ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 05/08/2025 12:41:13New subject after splitting |
| 5/8/2025 1:05 PM | |
I'm using the LFTP Library |
| 5/8/2025 3:16 PM | |
Joined: 7/7/2010 Last visit: 12/31/2025 Posts: 16342 Rating:
Are you making a single LFTP connection, and repeatedly sending over the single connection, or are you connecting (and disconnecting) for every FTP send? Did you follow the example LFTP application, or completely ignore it and attempt to make your own, or some of both? Did you read the diagnostics.subfunctionStatus after getting the 16#8604 message about the TCONSETTINGS error? Are you going to post screenshots of your LFTP call(s) so we can compare against the example application to see what might be wrong? Has this worked before and suddenly is not working?
science guy |
