11/20/2024 11:42 AM | |
Joined: 5/7/2020 Last visit: 8/13/2025 Posts: 9 Rating:
Hello Team, I want to integrate this module with S7-1516 PN PLC in TIA portal , getting this error in the diagnostics buffer, can anyone tell me will this module is compatible with this PLC. Module exists. Additional information for the module: Thanks in advance!! ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 11/20/2024 12:25:34New subject after splitting |
11/21/2024 9:52 AM | |
Joined: 5/6/2022 Last visit: 9/9/2025 Posts: 589 Rating:
Hi puttarajuv, - What version of TIA Portal are you using exactly? - Can you share a screenshot of the error or this message? - Is this reference you are using from any third party GSD? - What reference and firmware version does the equipment physically have and what reference and firmware version do you have configured in the project? We are waiting for your answer. Best regards!
