12/11/2024 4:15 PM | |
Joined: 7/7/2010 Last visit: 9/12/2025 Posts: 16094 Rating:
Perhaps you can try searching this support site. For example, I found this prior forum topic that may be helpful: From documentation for the MB_MASTER block:
If you are following all those rules, everything should work - provided you also followed the requirements for the various block parameters. It's rather tricky how they require the re-use of the instance DB for all MB_MASTER calls. This forum topic has a link to an example application plus other suggestions for PLC code implementation concepts: https://support.industry.siemens.com/forum/WW/en/posts/s7-1200-modbus-rtu-with-12-slave/178837
science guy |
