2/2/2010 12:29 PM | |
Joined: 6/3/2009 Last visit: 8/20/2025 Posts: 101 Rating:
Dear Forum Members I had downloaded the program to MP 277,while restarting the os power failed. After that MP277 OS is booting up. I had tried OS Restore with help of manual, While updating OS to Multipanel power got off.After that not able to start.and not able to update too. I have simatic field PG and PPI cable as specified RS232/PPI Multimaster Cable, MLB NO. 6ES7 901-3CB30-0XA0. I had checked setting in MP the four dip switch in UP (ie. for PPI cable communication) After long time i had found that ports(MPI/DP,Ethernet,USB) presents in MP277 are failed. Wheater there is any way to check theports are working inHMI's. |
2/10/2010 9:29 AM | |
Joined: 5/28/2008 Last visit: 9/1/2025 Posts: 901 Rating:
Hello Wincc, Your only chance is to resetthe panelto factory settings. Something else is not possible. If that idea does not work please contact the Siemens Hotline, because only they can repair the panel. Here you get the contact: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=38718979&caller=view regards Manfred |
