1/30/2025 7:33 AM | |
Joined: 1/21/2025 Last visit: 9/5/2025 Posts: 5 Rating:
Hi, im using Wincc Comfort |
2/12/2025 1:20 PM | |
Joined: 8/3/2009 Last visit: 9/19/2025 Posts: 16461 Rating:
Hello this lines seems to be wrong: tag = a + index + b --> If you want to use the string out of 'tag' then you would have to write: valueTag = HMIRuntime.SmartTags(tag) But you should also read this Manual note: https://support.industry.siemens.com/cs/ww/en/view/109813306/109377913227 "Current system behavior for dynamic access to elements of a user data type"Bye Murof |
