4/30/2025 7:35 AM | |
Joined: 5/6/2022 Last visit: 7/10/2025 Posts: 589 Rating:
Hi Eduardo.Blanco, What versions of TIA Portal are you working with? Have you tried it with a new project? In other occasions, I have seen that this problem is due to the fact that the project may be corrupted and for this reason this problem occurs. Best regards!
