4/24/2025 1:08 AM | |
Joined: 10/28/2017 Last visit: 5/31/2025 Posts: 12 Rating:
Hi, I’m trying to set up my WinCC RT Unified V18 application as a OPCUA server. I managed to get it to work with UaExpert. I'm now trying to set it up with nodered(node js version 18 and node red v3.0.2) both locally(for testing only) and in a separate IOT device(IOT2050). however, it is giving invalid endpoint error (node-red-contrib-opcua-0.2.339). I suspect this has something to do with certificate because I struggled with UAExpert client on this. It did not automatically get generated in the rejected or trusted folder. I had to manually transfer it from UaExpert. I'm not sure how to do this in a debian/nodered setup. Additionally, if possible to setup wincc RT unified to allows no security mode/policy? This way I dont need a certificate. I watched this video(https://www.youtube.com/watch?v=shQFuXEK2Gc) but the content of the OpcuaServerRTIL.xml file much different than mine to edit. So im not sure how to do this. Please assist. thank you |
