9/14/2007 3:23 PM | |
Posts: 3 Rating:
Have you checked the diagnostic buffer? |
11/12/2007 12:28 PM | |
Posts: 25 Rating:
Hai all.. My problem was solved..The SF was always lit up because of Module failure. It was because of the improper connection of the P&F Encoder which made the module's Clock Driver ICs Burnt out. Found out by physically opening the module. We tested with a new fresh sm 338 module with a fresh 25 bit P&F Encoder which was working perfectly. The datasheet of the tested encoder is attached for your reference. Thank you..Hope it will help some one. Vishnu karthick Attachmentt17989_eng_AVM58_25bitabsolute.pdf (855 Downloads) |
