7/28/2017 8:35 AM | |
Posts: 215 Rating:
Can you link me to the Mindsphere tutorial, so I can have a shot at your problem? |
7/31/2017 5:38 AM | |
Joined: 6/20/2017 Last visit: 4/21/2025 Posts: 4 Rating:
Thank you very much for the response. We are in the process of procuring the right device. Thanks again. Ranjith |
8/3/2017 5:38 PM | |
Joined: 4/16/2015 Last visit: 2/25/2025 Posts: 45 Rating:
It's now possible to connect the SIMATIC IOT2040 to the MindSphere with the MindConnect Library. The MindConnect Library is a C/C++ based Library which allows you to connect the SIMATIC IOT2040 to the MindSphere. You need to program Connecting, Disconnecting, Buffering and Sending Mechanisms. A detailed tutorial how to do this is attached in the MindConnect Library Getting Started. In the first step only MindAccess Developer can download and use the MindConnect Library. So the MindConnect Library is for free, but to test it you need the MindAccess Developer in the first step. In further steps MindSphere will be more and more open so that MindAccess Developer won't be neccessary for pure connectivity anymore. That means in about half a year :-( the MindConnect Library will be free and usable without the Test Access. I have attached you a Document how to get started and a Link with MindSphere Documents. If we have tested the solution ourselfes over the next time we will put a more detailed tutorial in the IOT2000 Forum. AttachmentMindSphere_MindAccess_Developer_datasheet_en.pdf (618 Downloads) |
Last edited by: Philipp_ at: 8/3/2017 5:39:23 PMLast edited by: Philipp_ at: 8/3/2017 5:40:44 PM |
