5/15/2020 3:24 PM | |
Posts: 152 Rating:
Hi Denilson, I see you are very skillful with scripting in new WinCC Unified. I need a little help. I have a faceplate which I want to use on all new Siemens panels (7''-15''), but I can not find a way how to scale it. I can place it o the screen but when I want to make it bigger or smaler I can resize the faceplate but my .svg graphic inside of this faceplate stays the same all the time. There is certanly some way to dinamize width and height of my .svg graphic so it follows the width and height of the hole faceplate Do you have some idea what could I do? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/18/2020 06:41:49New subject after splitting |
5/18/2020 6:42 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8171 Rating:
Closed cause question posted twice. The second thread with the subject Scale faceplate with graphic is published within the conference WinCC Unified Systems. Best regards,Jen_Moderator |
