5/20/2020 11:24 AM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Hi, there is very much topics about this already. Did you already implement this fix? Best regards! |
5/20/2020 11:50 AM | |
Posts: 4 Rating:
Sorry! I missed those I'll give it a try EDIT: I changed the version string as advised in:
Rebooted the IoT2040 but still no luck. Besides my logfile didn't seem to complain about the node-red-node-intel-gpio in the first place. But it was worth a shot. I also found references to removing package-lock.json but that file doesn't exist on my system:
Could it be that I messed things up by trying to install nodes BEFORE I applied the above mentioned workarounds?? As suggested by Fe_lipe in this thread:
I also tried manually as per description in this thread:
But still no success :(
5/20/2020 1:35 PM | |
Hi, there is a problem with DNS and gateway using static IP. You need to add a gateway (routers IP address) to /etc/network/interfaces. And here is an instruction for the DNS. With these two thing you can stick to static IP, if you want Best regards! |
