10/11/2020 12:17 AM | |
Joined: 9/27/2006 Last visit: 9/12/2025 Posts: 12407 Rating:
Hello M. Goktug; Your situation is very similar to the one analyzed in this document, where a CPU 315-2DP is set as slave to another S7 CPU, configured in another Step 7 project: https://support.industry.siemens.com/cs/ww/en/view/19449428 Follow the guidelines to configuring the CPU 315-2 DP as a slave, then create the master-slave exchage areas before bringing the slave into the Delta V master system with the S7-315-2DP gsd file, as the document shows for the S7-400 DP master. Hope this helps, Daniel Chartier |
