10/30/2009 5:32 AM | |
Posts: 382 Rating:
Dear sundar, The netpro you have posted is in .jpg, not possible to modify I have attached a SWR setup notes for you to do your setup. If you still not able to do it successfully you can post your lastest program setup here or email me your program if you want. I will help you to do the setup I hope these notes are useful to you and to otherswho might need it. with regards, how come? AttachmentSWR Setup Notes.zip (562 Downloads) |
Last edited by: how come? at: 10/30/2009 6:24 AMLast edited by: how come? at: 10/30/2009 6:23 AMLast edited by: how come? at: 10/30/2009 6:22 AM |
10/30/2009 8:53 AM | |
Posts: 100 Rating:
Thanks how come. I get that netpro setup. but i couldn't check with field because i am in office. is there anyway to check redundancy without hardware. i upload my latest program below if any modification in my program pls correct me. i should go with 100% working program to site. why because its difficult to get internet specility in site. help me. Best regards, V.Sundar. AttachmentTUBE_CLEANING_SYSTEM.zip (549 Downloads) |
10/30/2009 10:37 AM | |
Posts: 382 Rating:
Dear sundar, As what I know of there is no way that can confirm/verify SWR setup got no error without downloading and test together with the hardware. Thus you still need the hardware. I am not sure about how your plant/system work thus I didn't check your logic folders FCs,FBs,etc. Hope this helps! And good luck for your testing!! with regards, how come? AttachmentTo sundar 2.zip (563 Downloads) |
