7/1/2025 7:54 AM | |
Joined: 8/3/2009 Last visit: 9/12/2025 Posts: 16409 Rating:
Hello AutoGen_5e8a1 first of all, which HMI do you use? you have to check if the HMI conntection from your PLC Sim is established to your HMI simulation: https://support.industry.siemens.com/cs/de/en/view/109748099 check also: https://support.industry.siemens.com/cs/de/en/view/88193789 you can also use an alarm window and check the systemalarms at startup if the HMI connection to PLC is established or not Bye Murof |
