7/3/2025 12:11 PM | |
Joined: 3/22/2025 Last visit: 7/7/2025 Posts: 3 Rating:
I want HMI digital clock time to be transferred to PLC. I'm using WinCC RT Advanced for HMI. Kindly guide in this regard. |
7/29/2025 6:40 AM | |
Joined: 8/3/2009 Last visit: 9/3/2025 Posts: 16322 Rating:
Hello @AutoGen_666260 do you still need help? Check out this FAQ: https://support.industry.siemens.com/cs/ww/en/view/69864408 You should also consider this FAQ if you have problems with user rights in Windows setting the Clock: http://support.automation.siemens.com/WW/view/en/59203176 Bye Murof |
