2/26/2019 5:59 AM | |
Joined: 2/27/2018 Last visit: 4/21/2025 Posts: 1 Rating:
Hi, Hello, I am trying to use the smart counters of the s7 200 smart, but I do not understand how to configure it. Could someone explain how to configure these counters? I will be grateful. The input I am using is I0.2, with a proximity sensor that is coupled to a base and generates 25 pulses per revolution per gear tooth. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/26/2019 7:19:44 AMNew subject after splitting |
2/26/2019 8:13 AM | |
Joined: 7/9/2015 Last visit: 8/29/2025 Posts: 4443 Rating:
Hi, please check the following FAQ or the link to manual. How do you count values over 16 bits with the S7-200? The Counter instructions you will find in manual page 113 and following. Regards, Towome |
2/26/2019 8:38 AM | |
Posts: 2826 Rating:
Hello. We are blocked by Siemens from using the S7-200 SMART product range. The closest I can get you is the System Manual. One page of this manual is added as a PDF. Search the manual on Siemens' web page. Mention is made of a configuration wizard. See the in-software help for a description on this. This wizard will write some code for you. BR Attachmentpart-S7-200-SMART-System-Manual.pdf (390 Downloads) |
