1/25/2021 5:58 PM | |||||||||||
Joined: 11/10/2010 Last visit: 7/16/2025 Posts: 172 Rating:
Hey Zankkar, the active bus module is ordered separately, about the IM153-2 for redundancy, ther's a bundle red to be ordered (02 IM + Activ Bus) , please refer the MALL siemens Best regards
1/25/2021 6:37 PM | |
Joined: 2/7/2020 Last visit: 6/27/2024 Posts: 101 Rating:
but modules mentioned is supported by IM 153-2 rt? I will order sepeate bus modules. thank you..!! |
1/26/2021 12:32 PM | |||||||||||
Joined: 5/28/2008 Last visit: 9/3/2025 Posts: 4522 Rating:
Hello, As told before, the above IO modules don't come with active bus modules. It comes only with backplane for each module inside the box. which will be not necessary for your case here. You have to order for these 4 modules, Qty 2 Bus unit (6ES7 195-7HB00-0XA0). For IM 153-2 all mentioned modules supports IM redundancy / Bus Redudnancy and you can use with IM153-2HF but will need to order budle to save some money. Part No. of Bundle (6ES7153-2AR04-0XA0) and please note that:
Hope this helps |
Ayman Elotaify |
1/26/2021 2:17 PM | |
Thank you for detailed information.. |
