10/18/2020 8:15 PM | |
Joined: 3/28/2015 Last visit: 8/15/2025 Posts: 725 Rating:
Hello, Perhaps the following topics might help: 6ES7317-2AJ10-0AB0SIMATIC S7-300, CPU 317-2DP, Central processing unit with 512 KB work memory, 1st interface MPI/DP 12 Mbit/s, 2nd interface DP master/slave Micro Memory Card required. 2-Successor product: CPU317-2 DP, 1 MB 6ES7317-2AK14-0AB0SIMATIC S7-300, CPU 317-2 DP, Central processing unit with 1 MB work memory, 1st interface MPI/DP 12 Mbit/s, 2nd interface DP master/slave Micro Memory Card required. 3- What should you watch out for when changing from one S7-300 CPU to another? |
Eng.Mohamed Ibrahim |
10/19/2020 11:09 AM | ||
Posts: 66 Rating:
Dear, thank you for your reply, the first CPU looks like it has the same size of Ram comparing to mine so i dont think that will be my choice but the 2nd one looks bigger. after looking into your links, i will go with
thank you for your support, i hope my GSD files does not get spoiled after changing with new CPU and install the new hardware |
