(0)| 3/31/2021 9:02 AM | |
Joined: 3/14/2008 Last visit: 1/19/2026 Posts: 2233 Rating:
Hi, You can change this in the Plant Hierarchy settings in Plant view under: Create/Update Block Icons: Right click the OS project->Plant Hierarchy->Create/Update Block Icons and select the correct tagname selection under: "The object name TAG is made up..." |
Last edited by: Oreca at: 03/31/2021 09:03:07If I could help you, you can use the RATE button. Thank you. |
| 3/31/2021 9:32 AM | |
Hi, Have you tried changing the HID as well? You can find it under Plant Hierarchy->Settings and deselect: "Included in HID" |
| 3/31/2021 1:00 PM | |
Posts: 12 Rating:
Hi Oreca I have tried Included in HID option as well. If you check my pervious picture it will be Plant Hierarchy folder name/chart name/block name (PS1/VLV1/1). I have tried by various setting in "Included in HID" as well. Still tag name in faceplate is Chart folder/Block name (VLV1/VLV-1) attached picture for your reference. Is there any other option or can you share me picture of Plant Hierarchy setting Attachmentpicture.docx (208 Downloads) |
