(0)| 12/16/2021 11:21 AM | |
Posts: 22 Rating:
Hello. I need to update my firmware on the CPU 1214C DC/DC/Relay (6ES7214-1HG30-0XB0) in order to access the PLC with TIA Portal V15.1. I currently have the V1 on my PLC which is not available in TIA Portal V15.1 (i can only choose 2.X) so i can't acess it. but i can't find the any sort of firmware available online except for the 6ES7214-1HG31-0XB0 and 6ES7214-1HG40-0XB0 versions, can you help me? Thanks in advance. SOLVED! For those who may face the same problem just download the firmware from the following link: https://support.industry.siemens.com/cs/ww/en/view/38709962 Then, check the manual (link below) on page 115, chapter 4.5.5 (Firmware update) in order to perform the update correctly. |
Last edited by: Estriga at: 12/16/2021 13:00:53Last edited by: Estriga at: 12/16/2021 13:03:05Last edited by: Jen_Moderator at: 12/16/2021 14:00:43Optimized links. |
| 12/16/2021 11:41 AM | |
Joined: 3/30/2020 Last visit: 1/21/2026 Posts: 5670 Rating:
Hello. Operating system updates for CPU 1214C, DC/DC/RELAY Caution: You will be prompted to register to the next level of authorization to enable you to download the firmware V2.2 file. You can only update the PLC by using a special external Siemens memory card. Read the information on the web page carefully. ~ |
| 12/16/2021 11:45 AM | |
Posts: 22 Rating:
Thank you so much. I really searched for it but couldn't find it for some reason. That's what i'm looking for. I will give it a try and get back to you. |
| 12/16/2021 12:58 PM | |
Posts: 22 Rating:
It worked. Thank you so much! |
