1/27/2022 11:41 AM | |
Joined: 4/30/2021 Last visit: 3/28/2023 Posts: 9 Rating:
Hello! How does the contacts on the pre-contacted Profibus cable from Siemens look like? Product: 6XV1830-3DH50, Product Details - Industry Mall - Siemens Sweden we have a cable from another manufacturer that doesn't work since the contacts are wrong. attached image of what we want the connectors to look like! Br Johannes |
1/27/2022 2:00 PM | |
Joined: 9/27/2006 Last visit: 9/11/2025 Posts: 12406 Rating:
Hello; One of the best sources of information on pre-constructed Profibus cables is this document, section 6.5: https://support.industry.siemens.com/cs/ww/en/view/35222591
Can you give us the non-functionning cable's make and model, so we can help you determine why it does not fit Profibus standards? Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 01/27/2022 14:05:14Last edited by: dchartier at: 01/27/2022 14:07:30 |
1/27/2022 3:27 PM | |
Hello Johannes; Look up the product number of your (not-connectabe-to-Profbus) cable, and search for its description on Lapp Kabel's website. Lapp Kable manufactures Profibus cables using B-coded M12 connectors, as you can see in the screenshot below. For DeviceNet, they use A-coded connectors, for example, and these will not fit in a Profibus device. Hope this helps, Daniel Chartier Edit: see here for a visualization of the different M12 coding formats: https://blog.muellerelectric.com/m12-cable-coding-decoded-which-is-right-for-you-1-0 D. C. |
Last edited by: dchartier at: 01/27/2022 15:35:04Last edited by: dchartier at: 01/28/2022 22:26:38 |
