12/25/2021 6:59 AM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating:
Hello bandr, 230005 - Power unit I2t Overload - Check r0036 value 230021 - Power unit ground fault, check fault value in r0949 025201 - Drive fault. From above fault numbers & description you provided, check motor supply cable, encoder cable, motor IR value,loading of axis, lubrication etc. etc. If all these checks are OK, then you need to check by replacing axis power module. Hope this helps. |
10/26/2022 1:42 PM | |
Joined: 9/6/2014 Last visit: 10/21/2024 Posts: 209 Rating:
Hi That's right , I sure you had hardware problem . perfect |
