(0)| 11/23/2022 1:49 PM | |
Joined: 6/30/2018 Last visit: 7/21/2025 Posts: 11 Rating:
Hi, Can you Help me in Identifing/Locating the Excel addin File,that i can't able to find. Thanks in Advance! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/24/2022 08:33:03New subject after splitting |
| 11/24/2022 8:09 AM | |
Joined: 6/22/2017 Last visit: 1/20/2026 Posts: 424 Rating:
It should be in the folder you showed (if you did not change it in the installation, if that is even possible) are you sure you installed the reporting? This is not automaticly installed with the TIA Portal or with the Runtime. It's a separate installer. Greetings |
