(1)| 4/20/2023 12:46 PM | |
Joined: 10/16/2007 Last visit: 1/21/2026 Posts: 658 Rating:
Hello, you can check here. Is a little older but still ok. Regards Scott |
| 5/4/2023 10:09 AM | |
Joined: 8/3/2009 Last visit: 1/21/2026 Posts: 16653 Rating:
Hello It would be also a solution using simple OPC UA Clients: https://support.industry.siemens.com/cs/de/en/view/109748892 Or using the built in userdefined Webpages of the S7-Webserver: https://support.industry.siemens.com/cs/de/en/view/68011496 Bye Murof |
