4/1/2024 5:56 AM | |
Joined: 10/3/2023 Last visit: 8/20/2025 Posts: 53 Rating:
Hi all, I have a CPU1214C (6ES7 214-1BG40-0XB0), I checked the online & diagnoses to check the software version and firmware and it shows that v13 and firmware 4.1.3. so, i downloaded the tia portal v13 sp2 to take backup from the PLC. but, it shows the error, " the hardware configuration was created and downloaded with an incompatible version of step7.could not upload hardware configuration." I need to take the backup from plc. I also using the same version shows in online & diagnosis. I checked for SP1 software but it not available now. How to take backup from that unit. Kindly, explain this. Thank you ------------------------------------------------------------------------------------------ |
Last edited by: Riyasa at: 04/01/2024 05:57:54Last edited by: Riyasa at: 04/01/2024 06:11:42Last edited by: Jen_Moderator at: 04/02/2024 05:04:39New subject after splitting |
4/2/2024 5:05 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8171 Rating:
Closed cause question posted twice. The second thread with the subject Tia Portal V13 upload is published within the conference STEP 7 (TIA Portal). Best regards, |
