4/16/2024 1:40 PM | |
Joined: 4/16/2024 Last visit: 9/5/2025 Posts: 1 Rating:
Hello, I have same error installed on Windows 10 x64 2016 LTSB FC201901.01. I am confused because Supported operative systems on pdf install guide LTSB it´s valid but on same pdf, 1.1 Wincc installation notes describes that supported o.s its LTSC..... Any idea? I am trying to open support request but only WinCC 7.4 its listed...... Thanks in advance ------------------------------------------------------------------------------------------ |
Last edited by: AutoGen_7928243 at: 04/16/2024 13:42:20Last edited by: Jen_Moderator at: 04/17/2024 08:12:07New subject after splitting |
4/17/2024 12:08 PM | |
Joined: 8/3/2009 Last visit: 9/12/2025 Posts: 16409 Rating:
Hello AutoGen_7928243 so, which exact WinCC Vrsion do you want to install on your OS (Which ne with Build Nr)? -> LTSC and LTSB is quite the same Microsoft renamed LTSB in LTSC https://support.industry.siemens.com/cs/de/en/view/109792955 Bye Murof |
