9/11/2024 9:36 AM | |
Joined: 8/3/2009 Last visit: 9/15/2025 Posts: 16409 Rating:
Hello AutoGen_1279993 basically you can use the Selection dialog for selecting the Timerange for the Data in the Table control (if you use different time bases, then use a seperate time column for each value column). To play around with script to dynamize during Runtime you can use this FAQ as base: https://support.industry.siemens.com/cs/de/en/view/11942662 tablecontrol and trendcontrol are similar but have a few differences Bye Murof |
