1/18/2025 12:43 PM | |
Joined: 1/13/2025 Last visit: 2/3/2025 Posts: 1 Rating:
I have a similar problem uploading the Logo Comfort 8.4 upgrade. I have Windows 7 32 bit, I upload the 32 bit version, and every time I get an error ‘ Windows error 216 occurred while loading the Java VM ...’. I have reinstalled the system, loaded the older Java and got the same error every time. I suspect that the 32 bit installation version is corrupted. please find a version that can be installed. Translated with DeepL.com (free version) ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 01/20/2025 09:37:08New subject after splitting |
1/22/2025 3:08 PM | |
Joined: 7/10/2024 Last visit: 8/22/2025 Posts: 180 Rating:
Hello! The first thing I would check is that you're doing all of this with admin rights. I attach a SIOS FAQ that you may find usefulI. https://support.industry.siemens.com/cs/ww/en/view/77979929 I would also check that you have updated the Java version. Finally, I recommend that you download a fresh copy of the installation file to make sure it's not corrupted. You can review SHA verification. https://support.industry.siemens.com/cs/ww/en/view/109483101 I hope it helps 🍀 |
If you found this post helpul, I'd greatly appreciate your feedback with the rate function |
