7/25/2019 10:32 PM | |
Joined: 7/19/2019 Last visit: 1/30/2025 Posts: 1 Rating:
Hi I was working with TIA PORTAL V15.1 on windows 7 and all worked, I'm starting using TIA Portal V15.1 on windows 10, same project and same fonts. I compiled my HMI TP1200, and i started to have problems with types of fonts that i used. *Siemens TIA Portal Icons *Free 3 of 9 Extended I checked others post solutions about that, I've already modifed language for non-unicode to english (US) , but it did't work Is there something to setup? Please see attached photo. Thank you very much ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 07/26/2019 11:19:33New subject after splitting |
2/12/2025 1:10 PM | |
Joined: 8/3/2009 Last visit: 9/10/2025 Posts: 16386 Rating:
Hello there is also a description how to install Fonts for TIA Portal in this FAQ in Documentation in Chapter 32.2: https://support.industry.siemens.com/cs/de/en/view/106226404 Bye Murof |
