9/4/2025 10:46 AM | |
Joined: 8/3/2009 Last visit: 9/16/2025 Posts: 16436 Rating:
Hello kulmx Its not clear which question, problem or usecase you have... Could you give us a few more information on what you want to do exactly and where are your questions/problems? If you want ot access a SQL Database with VB Script in WIncC Professional you can use a similar way than this: https://support.industry.siemens.com/cs/ww/de/view/61883659 (Its for Advanced RT but the way is the same in WInCC Prof, only a few changes on the professional specific syntax) Bye Murof |
9/4/2025 1:46 PM | |
Joined: 1/15/2007 Last visit: 9/10/2025 Posts: 53 Rating:
Hello Murof I used this solution to write to the SQL database (ID 61883659) |
